The build with the latest commits is: g43c4482aaI see two 386.7 alpha releases for AC86U and AC5300 in the downloads folder. Have not downloaded them yet but was wondering, are these too different even though they are for the same model?
The RT-AC86U and RT-AC5300 are completely different devices.
Yes I know [emoji106]. But was talking about the fact there are two alpha releases for each model in the download folder and wasn’t sure which one to download for each device. I have both of these routers.
Thank you
I have 3+ days on the latest Alpha, and not a single reboot.Anybody getting reboots on the 86U?
Can't find anything in the system log but my router's up time is never over 24 hours.
Rolled back to stable 384.6 without a reset and already have almost 2 days without a reboot.
Aug 13 23:51:18 RT-AC68U-4690 kernel: nvram: consolidating space!
Aug 13 23:52:24 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 00:00:00 RT-AC68U-4690 syslog-ng[885]: Configuration reload request received, reloading configuration;
Aug 14 00:22:25 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 00:47:32 RT-AC68U-4690 kernel: nvram: consolidating space!
Aug 14 00:52:25 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 01:22:26 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 01:52:26 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 02:22:26 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 02:52:27 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 03:22:27 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 03:42:06 RT-AC68U-4690 dnscrypt-proxy[559]: Server with the lowest initial latency: cloudflare (rtt: 9ms)
Aug 14 03:52:28 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 04:22:28 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 04:52:28 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 05:20:04 RT-AC68U-4690 tOmsK: AB-Solution counted ads and rotated log files (daily cron job)
Aug 14 05:20:04 RT-AC68U-4690 tOmsK: AB-Solution blocked 6,807 total 1,443 week 738 new ads
Aug 14 05:20:22 RT-AC68U-4690 syslog-ng[885]: The current log file has a mismatching size/inode information, restarting from the beginning; state='affile_sd_curpos(/tmp/mnt/Data/adblocking/logs/dnsmasq.log)', stored_inode='130827', cur_file_inode='130835', stored_size='2774161', cur_file_size='473', raw_stream_pos='3223961'
Aug 14 05:22:29 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 05:52:29 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 06:22:29 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 06:52:30 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Aug 14 07:22:30 RT-AC68U-4690 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
I noticed DNS Filtering is missing under AiProtection?
Welcome To SNBForums
