dave14305
Part of the Furniture
Yes, all the old hardcoded rules from FreshJR are now editable or can be deleted.
I’m not sure I really see the need to pick on Snapchat by default, so maybe it will disappear from default setup in a later version.
Thanks!Yes, all the old hardcoded rules from FreshJR are now editable or can be deleted.
LOL, you mean a default list of changes that people make to the defaults?Thanks!
is there a link/doc with recommended common changes to the default setup?
feel silly now...LOL, you mean a default list of changes that people make to the defaults?
Depends on what's important to you.
I know what you meant. I just didn't have a good answer.feel silly now...![]()
So do you call yourself "U.G. Andy" or "U-gandy"? I always hear "U-gandy" in my head when I see your posts.![]()
sh /jffs/addons/flexqos/flexqos.sh update
I have 15 down and 1.5 up. I don't know what you consider small bandwidth. How would I test and report results? While I have 25 years of IT experience, I barely have a grasp of what I'm doing with regard to IP Tables, QOS, etc.Version 0.9.3
- The quantum change is in need of much testing, especially those of you with small bandwidth. I've currently set a floor of MTU+14 for minimum quantum, but I don't know with any certainty how this would work at low bandwidth.
Only showing 9.2 version here....Version 0.9.3
- NEW: Override tc quantum when over 200000 or under the WAN MTU size (this should minimize any warning messages in syslog)
- NEW: Added ability to switch between stable and development channels (webui and script will show if not on stable channel)
- NEW: Added SNBForums.com SPOILER and CODE tags to debug output for cleaner copy/paste when posting
- CHANGED: When A.QoS is disabled, the FlexQoS button will direct you to the QoS page when clicked (thanks @thelonelycoder)
- CHANGED: Custom URL enhancements (contributed by @maghuro)
- CHANGED: Added enter prompts after interactive menu choices
- CHANGED: Removed VPN Fix that has been in Merlin since 384.8
- FIXED: Fix issues with AppDB names missing after a reboot
- FIXED: Hide extra "Reset" next to iptables rule add button
- FIXED: missing restore prompt on re-install
- FIXED: Fix issues where the WebUI page might change unintentionally when the script runs
The quantum change is in need of much testing, especially those of you with small bandwidth. I've currently set a floor of MTU+14 for minimum quantum, but I don't know with any certainty how this would work at low bandwidth.Code:sh /jffs/addons/flexqos/flexqos.sh update
FlexQoS v0.9.2 released 07/09/2020
Advanced configuration available via:
http://192.168.1.1/user1.asp
Would you like to restart QoS for modifications to take effect? [1=Yes 2=No]: 1
Restarting QoS and Firewall...
Done.
QuikSilver156@RT-AC86U-AEA8:/tmp/home/root# sh /jffs/addons/flexqos/flexqos.sh u
pdate
Checking for updates
You have the latest version installed
Would you like to overwrite your existing installation anyway? [1=Yes 2=No] :
Yes, post 1 was correct. Updated post 487.guys 0.9.3 is probably just a typo...
Run flexqos debug where you will see new lines for Quantum. I’d like to know if any are not “default”.I have 15 down and 1.5 up. I don't know what you consider small bandwidth. How would I test and report results? While I have 25 years of IT experience, I barely have a grasp of what I'm doing with regard to IP Tables, QOS, etc.
edit: We have switched to streaming "television" services and several of them show up as web traffic. I have no understanding of how to add rules to change that. I'd be glad to test though.
Today develop and master are equal, so no benefits. But the syntax is:@dave14305
What the link for trying development branch? Is 0.9.3 in develop branch as Master showing 0.9.2 latest?
Second, is it OK to overwrite dev branch on master?
flexqos develop
Or
flexqos stable
No, you should just use multiple AppDB or iptables rules. Are you talking about an AppDB rule, or an iptables rule?Hi, is it possible to set multiple marks into one same rule?
I have multiple marks which I know belongs to file transfer and not websurfing.
Please give an example. Do you mean hardcoded rules in the FreshJR script?is there a way to save the hardcoded rules in the script by updating ?
Whats the difference? I always used iptables for rules because on freshjr's qos appdb was not working so I never investigated whats for appdb.No, you should just use multiple AppDB or iptables rules. Are you talking about an AppDB rule, or an iptables rule?
If you always want all instances of a Mark to go to a different Class (and its priority), use an AppDB rule. If it’s only for certain connections, use an iptables rule to filter on IP or port as well.Whats the difference? I always used iptables for rules because on freshjr's qos appdb was not working so I never investigated whats for appdb.
But on FreshJr's he had just 3 iptable rules to set and I'm switching to your fork [emoji846]
Using S.G.S9+ Duos w/ Tapatalk
We use essential cookies to make this site work, and optional cookies to enhance your experience.
