Folders Permission is not set in Samba/FTP share pages on N66U
White_Knight
Hello,
I have a problem with set permission ( R\W - R - No )on pages :
/Advanced_AiDisk_samba.asp
/Advanced_AiDisk_ftp.asp
Two important point:
1. I can see HDD in Router system ( Model and Size is correct )
2. I see and mount point ( for example sdd5 )
When i try to add New folder i see in title of "Add new folder" dialog
this string "Add new folder in undefined"
System can't find mount point of HDD
Because of this, I can't rename, delete, set permission of that HDD( i can't try other for test because i have not )
From Terminal i can see mount point by mount command
First think - HDD problem , but on computer i can do everything with that device
Second , i lost permission information on it
This issue on FW .43 and now with 376.44_alpha4
Have you considered reformatting the drive?
If you give more information on the drive, that might help-
How big is it?
How is it formatted?
Manufacturer/model?
How big is it?
Manufacturer/model?
I try reformatting drive repeatedly from my current Ext3 to NTFS ( i think it reformatting partition system information ) and again in Ext3. Today i think to wipe this drive.
Model of HDD is Seagate 250 Gb 3.5'' connected through that Dock station ( this connection from first time is working )
http://www.amazon.com/dp/B0047P77HI/?tag=snbforums-20
As i say, i can see this drive mount point and work with it from terminal,
I try to set permission from term. and i got shared folder in \\Samba\share\list on my computer but in Web GUI i can't set permission ( permission checks is disappear )
Info: i has 2 connected drive ( flash and HDD ), flash drive is working normally i see permission checks problem only with HDD
I try to reformatting by that programm on computer http://www.partition-tool.com/
