Forgot how to login via Powershell
foug
Hello, what is the command to login via powershell? ssh admin@[myip] -p[port] does not work. Thanks
That should work provided your user name is correct (admin - really?) and you remember the router password you've set
What's your error message? Have you executed ssh-keygen and copied the pub key to the router?
We all do it - just read my signature!
