You've lost me? What makes you so uneasy about those changes?
Read the changelogs of each...
I can't be 100% sure (no source and he didn't say)....but based on the descriptions I think the first four may be ports from my 374.43 fork.I quickly skim through the HGG-FINAL changelog. The following features caught my attention:
380.57: (5 JAN 16)
- NEW: WEBUI disable scan media (for dlna service) on boot option.
- NEW: WEBUI Power LED only option available on Stealth Mode.
- NEW: WEBUI save syslog to JFFS option.
- NEW: WEBUI support change HTTP port.
378.55: (19 JUL 15)
- NEW: FW logo.
I feel a bit uneasy. Is it only me? I scrapped half of my post after a second thought. Simply want to throw out a question for discussion...
Once installed - is it possible to revert back to 374.xx, 376.xx or 378.xx code level ?
On Merlin 380.xx you can not revert back to 378.xx/376.xx/374.xx - still valid ?
Also on 380.57.2 for 68u on setting the LAN-->DHCP Server-->Manually Assigned IP around the DHCP list "it works but ?? sets their quite a while if it even works! It final does work!"
FireFox 43.0 (OS) linux Mint 17.3
I didn't know there was an 380.57.2 out?
AC3200 but may apply to others as well.
This is not an issue with official or Merlin firmware. only on 380 HGG.
Been using the 380 final since release.
I can see 1 issue that maybe can be fixed:
Setting 5G-1 to a fixed channel seem to completely turn off 40/80 mhz bands on 5G-1.
I have tried these settings with various channels (36,40,44,48) for wireless modes:
- Auto
- N only
- Legacy
- N/AC only
in combination with:
- 20/40/80 mhz mode
- 20/40 mhz
- 40 mhz
only 20mhz connections are made. and Istumbler always say the router is broadcasting 20mhz only.
If I change the channel to "auto" on 5G-1, it binds to a high channel like 149,150 and 80mhz which kills the signal and no connections can be made.
(AC3200 has 2 5-G networks, 80mhz on 5G2 and channel 149 works perfect, the 5G1 only works on 36-60 channel , and is intended to. but with HGG firmware it jumps up to 140+ channel thus ruining the signal).
Only way to get it to show in router-overview (the wireless icon top right corner) with 40 mhz is if on AUTO channel and with some luck with numerous reboots where it finally puts itself on channel 36-48 so it can be used.
Can this be addressed? I want to get 20/40 or 40 only on 5G-1 with channel 36-48 so it can be used by the clients and get good signal.
Like can i run some command over telnet to change available channels for 5G1? meaning: remove all 149 and up.
No source can't check. It could be independent work. Or may be a port of john's work. If it's the latter, perhaps shall make it clear IMO and give proper credit.
So seems hggomes chose to selectively ignore discussion and did not bother to clarify a thing. Let me be blunt and put forward the question:
@hggomes, did you develop those four features independently by yourself?
I agree, not a big deal....it's open source, and if it is a port or he was able to use part as a guide, that's what open source is all about. I was just responding to someone who was concerned about the potential history of those particular updates. I'd suggest we just let it end there as far as any more discussion in this thread.Really? That was your question all along?
Isn't open source software supposed to be shared? I don't see what the problem is (even if he didn't 'develop' it himself).
but couldn't you just PM him this question instead?
I meant what are the USP or main themes, points of distinction between the three. That won't be apparent from all the details in the changelog.Read the changelogs for each.
If your not happy there are plenty of other options to use. Personally I don't have an issue and I am just glad we have options.?
When both sides are open source, it's trivial to everyone. I found this argument hilarious. Given many people encouraged hggomes to go open source, he refused. That violates GPL to begin with. Now you're saying john's fork being open source, could be shared..(referenced..copied..whatever you would like to put it).
In what right HGG fork cannot be open source. Not to mention that he violated GPL already which implies shall stop the operation immediately. Or better open up the source code to continue serving his users and the community better. Also let his operation be conducted openly on the forum.
Uh? I don't see this relevant..
Thread starter | Title | Forum | Replies | Date |
D | Release GNUton [Official Fork] 388.8_2 Release | Asuswrt-Merlin | 35 | |
D | Release GNUTON- 388.7_1 release [Official FORK] | Asuswrt-Merlin | 4 | |
J | How do I use GNUton's fork for my DSL-AX82U please. | Asuswrt-Merlin | 6 |
Welcome To SNBForums
