I don't have native IPv6, but do run an HE Tunnel....so don't think it's IPv6 related. The other thing that struck me as strange, is your internet graph was all 'blue'....blue is outgoing traffic????? Now from the data at the bottom, it looks like it may be overlaying outgoing data with incoming data (the in's and outs are virtually equal). That's why if you get a chance, it would be interesting to get some controlled realtime data.My connection is automatic DHCP, about the simplest imaginable. The only unusual thing is that I do have IPv6 enabled
Hello, I have just gotten a RT-AC68U, and started with the quick setup with the stock firmware, in that process I created a password for logging in to the router configuration WebUI, after that I updated with this firmware from this thread to try it out. Problem is now I can´t get back in in the damn thing, it won´t accept my password and nothing seems to work, I have tried the reset you recommen with pressing the WPS button for 5 seconds after starting the router up, I have also tried pressing the reset button both just once quick and holding it for 10 seconds, nothing happens, it it will prompt me for my username which is just: admin and then when i type in the password it just asks again and says its wrong (and yes I have checked CAPS)
Can anyone help or is just bricked??![]()
Sitting here with my new RT-N66U, and have research´d this merlin FW for a week now, and this!!! is why i have my dought flashing it... was about to to day But......
I have been manually turning off the LEDs by pushing the button at the back after each reboot. Is there a command to turn off all LEDs? Would like to add it into my startup scripts. Thanks.
Hi guys,If you did the reset propperly you should be redirected to the set up page by going to 192.168.1.1 then you would have to reenter all settings again. As stated a reset will reset the user name and password back to default. Admin,admin
Hi guys,
I finally got it to work, must have made some mistake, but it is up and running now. One thing though how do I do the factory reset after I have flashed it with the Fork Merlin firmware? The 5 second press WPS and start the router doesn't seem to work, what am I doing wrong? Or is it neccessary at all, everything seems to be working. Would like to know how it's done though.![]()
Hi guys,
So is this how i should do ?
Fork Merlin ( RT-N66U_3.0.0.4_374.43_2-13E1j9527.trx ) Asus RT-N66U
1. Simply flash it like any regular update. You should not need to
reset to factory defaults (see note below for exceptions).
You can revert back to an original Asus firmware at any time just
by flashing a firmware downloaded from Asus's website.
2.
resetting to factory default after flashing is
strongly recommended
(A factory default reset is NOT required if coming from any level of the fork or Merlin 374.42 or 374.43 code. Coming from any other level does require a factory default reset after the code is loaded.) Im on Asus`s New Firmware.
Thanks RMerlin!Enable Stealth Mode under Tools -> Other Settings.
Got itIf you reset using the WPS method you hold down the WPS button then power up the router and continue to hold down the WPS button for 15 seconds then release and wait for router to reset and boot.
You can also simply press the indented reset button while the router is on holding for 15 seconds then release the router will reset and reboot. Then reconfigure all settings and enjoy.
Welcome To SNBForums
