Updated the AiMesh node (AC68U) to 14_2 - will see if that addresses this node crashing issues that I posted about here - link
Will update the main node (AC86U) to 14_2 in a week or two!
This is the dcd process crashing. It's a Trend Micro component that is notorious for randomly crashing quite frequently - nothing that can be done about it, and shouldn't affect performance either.he only errors I see are on the two that have their radios turned off and that throws this set of error, which I assume are the radios being off...
No changes other than patches for AiCloud vulnerabilities.so far its looking like _2 is reliable.. any word on if it fixes the traffic analyzer issue only saving 1 to 24 hours? [I know.. this isnt the most important thing to most.. its super handy in my usecase]
@KGB7 Is this "hot swapping" issue definitely only present in this 14_2 firmware or has it always been problematic in previous firmwares, has @RMerlin been made aware of this bug?Found one issue with firmware 14_2 on Asus AC68U.
When unplugging an external drive from USB 3 port, the router will freeze and requires to be power cycled. But it happens randomly. Only way to avoid this issue is to log in to the router and click on the option to safely disconnect the hard drive. In other words, "hot swap" is buggy sometimes, but shouldn't be a big issue for most people, plus the router is EOL anyways. Still a great router and i'll keep it as a back up for a while.
On the plus side, GUI is still working well, very snappy and no issues that I have seen.
Welcome To SNBForums
