punchsuckr
Are you using DNS Filter to set nameservers for the laptop or somehow bypassing using the router dnsmasq as your nameserver? I think somehow some joker registered router.asus.com through a DDNS provider, so if you are bypassing dnsmasq it's getting resolved upstream.
If you're not deliberately bypassing the router as nameserver, if you running native IPv6, V16E1 that I just released may fix it.
Otherwise setting a hosts entry is probably the easiest fix.
Thanks for the response John, as a matter of fact I am using parental controls (via the router) on this laptop to use opendns instead of the router default (google dns)..I suppose this satisfies the criteria you mentioned?
Just waiting a day or two to upgrade to v16. Please do confirm if my existing openVPN setup will continue working normally after the upgrade.
EDIT: Updated to 16e1, couldn't wait
![Stick Out Tongue :P :P](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
