dnsmasq dies immediately.
Please define this.....what does 'die' mean?
what is the output of
ps | grep dnsmasq
what is the last log of dnsmasq in the syslog?
execute the following which will dump some data to the syslog....what does it say?
/usr/bin/killall -s USR1 dnsmasq
Cannot reply here, see http://members.ziggo.nl/slobodan/reply.txt
In case one wonders about the bad entries, here they are:
192.168.2.2 ▒supportjy2xvvdmx.onion
::1 ▒supportjy2xvvdmx.onion
The character is 92 (hex) or 146 (decimal).
Well I'll ask the silly question - have you tried removing those lines and restarting dnsmasq? Three quarters of a million hosts seems pretty intense.
Hi John,
Just updated my AC68U to v25E1.
Everything seems fine in Router mode. But whilst trying out in Wireless Bridge mode, l'm not able to save any changes made (keep processing...) cannot clear logs. or reboot router in GUI using IE or Firefox.
Need your advise.. Thanks
I have found the dnsmasq killer: it dies as soon as I ssh to the router (but not only then, alas).
Hi John,
Turn on the browser console (F12) and look under the console menu bar selection for any errors (things of interest are usually highlighted in red).
Actually, in the syslog you made available, the problems started long before you logged in. Something is hanging the startup so that a bunch of processes get put in a wait state.....it's either radvd for your 6in4 tunnel (don't think it's this one) or dnscrypt. With respect to dnscrypt...have you
  • updated the server listing? run 'update-dnscrypt-resolvers.sh' from the command line (I have this on a cron job that runs once a week)
  • Are you sure your dnscrypt servers aren't in your blocking_file? There is the possibility that there is a race in initially bringing up dnscrypt and dnsmasq....and if dnsmasq wins with the server in the blocking file, you are dead from the get-go.....otherwise, things will initially come up, then die quickly.
In any event, try with dnscrypt disabled.
@john9527
Sorry did not correct the issue for me. I have syslogs from both if needed. I have reverted back to 24E3
Did it, did not help.
Actually hosts block domain names, they don't block IPs. dnscrypt uses IPs for connecting to server, not domain names.
But it seems to be tied to dnscrypt, dnsmasq works fine without dnscrypt.
This is all I got.
NEW TEST BUILD - V25T3
https://1drv.ms/f/s!Ainhp1nBLzMJkEFTnFp4Sh2wvQva
@R1-Limited
Your syslog shows a completely different signature. At least part of what is going on was supposed to be fixed by backing out an RFC in the later builds. I'm now wondering if the RFC was just a way to trigger another problem in the code????
So, I cherry-picked a select set of fixes from 2.77 and made a custom 2.76fork dnsmasq. These fixes should be pretty safe and address the TCP retry problem I was having on Linux plus a couple of other problems that seemed should be addressed.
@slobodan
On a hunch, I made a couple of changes to the startup sequence for dnscrypt/dnsmasq. I'm thinking that loading that huge hosts file may be interfering with the dnscrypt start.
@Lotta Cox
You are always welcome to give this a try as well (same for anyone else).
