john9527
Part of the Furniture
Sure didOk. Changed back to admin and it works.
So did I find a bug?
Sure did....it was an ASUS code block that got pulled in. Already wrote the patch.
Same bug I had. Change your login name to admin or make that script thingy. Look back a few posts.When Im on 25E8 I can see all shared content on Kodi under Windows Network (SMB) but when Im on 26E3 There is nothing there. To do it I have to manually specify smb://and my pc Ip.
Never changed login name and its adminSame bug I had. Change your login name to admin or make that script thingy. Look back a few posts.
Works fine on my Kodi. I have 2 USB drives attached to a 68U.Never changed login name and its admin
If you aren't using router USB drives, I don't see how it's related to the router firmware. One thing about Kodi, it still uses SMB1 for it's sharing. You can't disable SMB1 on the PC.I dont have usb drives. All my content is shared from my pc to kodi boxes its been fine up until new firmware. Reverted back to 25e8 and everything is fine
I dont know how john but on 25 fine on 26 have to manually specify my pc ip not big deal just thought ill share my experienceIf you aren't using router USB drives, I don't see how it's related to the router firmware. One thing about Kodi, it still uses SMB1 for it's sharing. You can't disable SMB1 on the PC.
I also have no issue when sharing from a PC drive to Kodi on another PC. And with Kodi on a Nvidia Sheild.I dont have usb drives. All my content is shared from my pc to kodi boxes its been fine up until new firmware. Reverted back to 25e8 and everything is fine
Mine is to Kodi running on a Fire TV and a Fire TV Stick over AC wireless. Sharing, no problems. HTPC is running Win7 Pro.I also have no issue when sharing from a PC drive to Kodi on another PC. And with Kodi on a Nvidia Sheild.
Sorry, but it's a little unclear what you are asking about....Just wondering with the latest merlin firmware, AC68U C1 can still flash it but no support for troubleshoot or just can't flash at all? Thanks
380.57? = * 380.67380.57
380.57? = * 380.67![]()
The latest Merlin firmware starting with 380.57 also supports the AC68U C1 and later revs of the AC68 design with the newer processor.
This fork as of right now doesn't support the later revs. I'm currently working with someone on testing a fork version that will support the newer revs, but it isn't generally available yet.
Probably related to the code history....I'm pretty sure the original ASUS implementation didn't have the ability to disable the WAN access (Merlin added that), so it made sense to use the DDNS name if it was available.Setting it to the DDNS Host Name just seems a strange choice to me
Welcome To SNBForums
