I had a couple of router crash/auto reboots today on RT-N16 with 374.43_28E2j9527 , both involving USB HD access. Not sure if it is an issue with the recent changes, a prior issue, or a hardware issue from my end.
Crash 1: A computer on the LAN with Kodi was playing a movie that was stored on the USB HD plugged into the router, utilizing Network Place (Samba). This was the 3rd movie in a 24 hours period to play and the first two played without an issue. About 20 min before the end of the movie the router rebooted itself.
Crash 2: While a lot of torrent traffic was going to one of the computers on the LAN, that LAN computer initiated copying a 2+ GB file to the router's USB HD using SCP (via WinSCP). After a minute or so the router rebooted itself.
About the USB HD:
$ fdisk -l
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sda1               1      243202  1953512448   7 HPFS/NTFS
$ df /dev/sda1
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda1            1953512444 1567659040 385853404  80% /tmp/mnt/V
The last change that even comes close to the USB support on the N16 was the Samba 36/SMB2 support in V26. If you had that level on previously, there should be no other later changes that would affect the USB.
Since there aren't any logs on the N16 after the crash, it's tough to guess. Just for safety, I'd move the drive to a Windows PC and run a chkdsk (I see it's an NTFS drive).
Otherwise, I'd agree with @cybrnook that it's probably a problem running out of memory, and you may want to set up a swap file if you haven't done so already.
Superfly74
Do you know what version i need for 200 mW.
I have hggomes firmware but dont think its stabil and there you can turn it all the way up. But i need the 200 mW because my flat is in several floors and a wery crowded area.
And what will you do to improve reception of the requests being sent from the client devices?
Most routers is on auto channel selection and i live in crowdet wifi area. When my signal is stronger then the other routers change channel og i have better reception.
Is that simpel.;)
I know it work because i now use Hggomes firmvare.
I did find solution for the problem with John fork via nvram commands via putty.:)
I'm a longterm Shibby user who stopped upgrading when he started dual-WAN, I've now made the leap to Merlin (N66U 28e2) and looking at the traffic monitor when displaying in Kb/s everything seems fine, however switching to Mb/s the readings are 10 * actual usage.
I think there's a variable being used incorrectly. Am I the only person experiencing this - this was a fresh install no migration.
I think what he is doing is taking a particular channel by brute force, so the others change to another one and somehow his clients have a cleaner spectrum.
It is not much about signal strength between clients and router.
In theory might make sense, and the fact that it seems to work this way for him kind of proves that.
Before reading it, I would have said the same thing about clients not sending stronger than they are :)
It's not that simple.
However I'm not sure you're interested to listen to that.
Correct.:)
I do understand that the clients dont have the same power.
In other cases like when you want to put up a access point to the router is also make sence if both devices have more tx-power.
nice work
i love the new QOS screen
Take a look again at the units.....one is KB/s (KBYTES/sec - the original units from the code)...the other is Mb/s (Mbits/sec which I added). I'm sure its right.
EDIT: So there is actually an additional factor of 8X
and where can i make the switch from Kb to Mb?
That was added so long ago....I just moved it to the Traffic Monitor page with the rest of the new options (learned how to interface javascript with cookies and svg files :) )
Here's a comparison between KB/s and Mb/s
From the scales 5346.68 KB/s = 5.22MB/s = 41.77Mb/s
