treboR2Robert
@john9527
Sorry to say the new test build still doesn't work
1st connection worked fine. I then disconnected, waited for the client to disappear from "VPN Status" page on router and then tried to reconnect.
I think the errors are the same.
21:07 OpenVPN 2.5-icsopenvpn [git:v2.4_rc2-301-g14adf04a] arm64-v8a [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 3 2018
21:07 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
21:07 TCP/UDP: Preserving recently used remote address: [AF_INET]
21:07 UDP link local: (not bound)
21:07 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
21:08 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
21:08 TLS Error: TLS handshake failed
21:08 SIGUSR1[soft,tls-error] received, process restarting
I removed my ip from this incase you were wondering.
I tried it a few times on both android apps ( openvpn for android and openvpn connect )
Anything else i can try ?
