Getting this error with the latest build in AP mode
Jan  8 05:10:04 ntp: NTP update failed after 5 attempts
Have my default gateway set to my router's IP and also the DNS server to my router's IP.
Does anyone know what could be the problem?
in the latest dev version is have these errors
Jan  1 01:00:07 kernel: start_kernel
Jan  1 01:00:07 kernel: CPU revision is: 00019749
Jan  1 01:00:07 kernel: Determined physical RAM map:
Jan  1 01:00:07 kernel:  memory: 07fff000 @ 00000000 (usable)
Jan  1 01:00:07 kernel:  memory: 08000000 @ 87fff000 (usable)
Jan  1 01:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Jan  1 01:00:07 syslog: module leds-usb not found in modules.dep
Jan  1 01:00:08 kernel: NTFS (with native replay) support included
Jan  1 01:00:08 kernel: optimized: speed
Jan  1 01:00:08 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan  1 01:00:08 syslog: module cdc_wdm not found in modules.dep
Jan  1 01:00:08 syslog: module qmi_wwan not found in modules.dep
Jan  1 01:00:08 syslog: module cdc_mbim not found in modules.dep
Aug 17 12:52:56 crond[360]: time disparity of 5063691 minutes detected
What errors? Those are all normal messages as far as I can tell.
it's missing modules that's an error i think happened with compiling.
It always says it's missing modules of one sort or another, that's not an error in itself. Some of the modules are always missing and others are dependent on the router model. Are you comparing the messages to those generated by the previous firmware version? For example my RT-AC68U has always had the missing led module messages.
EDIT: A quick Search confirms that those other messages are normal for the RT-N66U. link
No matter where I look, I can't seem to find the different levels of NAT acceleration. Can someone point me in the right direction. I know it isn't CFE like in Tomato. Oof.
Should be LAN / Switch Control. I think it's been there since the early days, and would also apply to these LTS versions.
Sorry I don't understand the question. Are asking for an explanation of NAT levels, where to set it, see what it currently is, or something else? What router do you have?
If I remember correctly there used to be different settings/levels for NAT acceleration. I can't seem to find the settings. I have the RT-AC66U_b1. Should I set other settings a certain way for that option to become available?
LAN - Switch Control
Some models (I don't know which) only have one level of acceleration.
I'm afraid all I get is Enable or Disable. It shows the same as yours on my RT-AC68U. I'm also concerned because the CPU usage is higher on the AC66U_b1 w/ 1GHz processor than the AC68U with 800 MHz. I guess it only has one level. :(
I have the newest Dev version on both devices.
Check what it says at Tools > System Information > Network > HW acceleration.
Just "Enabled". Sorry to trouble you with this, but it was driving me a bit batty.
Thanks for you help, CT.
Sorry, I don't know any more. What is it specifically you're seeing that concerns you.
It's higher CPU usage on the 1GHz router during downloads, but I'm okay with it.
The firmware checks a value set by the kernel in the proc filesystem to determine if it's FA (CTF Level2) capable.
@joe a
What does
cat /proc/cpuinfo
show on the AC66U_B1?
Processor : ARMv7 Processor rev 0 (v7l)
processor : 0
BogoMIPS : 1998.84
processor : 1
BogoMIPS : 1998.84
Features : swp half thumb fastmult edsp
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : Northstar Prototype
Revision : 0000
Serial : 0000000000000000
@joe a
Hmmm...cpuinfo same as my AC68U and AC68P....
The AC68P supports FA, but my older AC68U doesn't
what about
cat /proc/fa
This doesn't exist on my 68U, but does with a value of '1' on my 68P
@joe a
what about
cat /proc/fa
Why would that be if both have the same CPU?
