Anyone have any thoughts on using LZ4 compression?
0bc4e07f12a537e5d99fbcb85d33c2ab8b7091607717b00b86315ba1bcf6b54c RT-AC56U_3.0.0.4_374.43_2-23E3j9527.trx
db67437e6bf3d9da19437d57c4c28fbd27a82a7c90764b4a950ef78af718c3e3 RT-AC66U_3.0.0.4_374.43_2-23E3j9527.trx
24ead2c41dde4124752259494396bd2f0b081c1037d86927951077f4251ba80e RT-AC68U_3.0.0.4_374.43_2-23E3j9527.trx
e083cdb01e9d912522a5d92f8cd53a8fc1dd5f54f0285b3250a2e64398255f0c RT-N16_3.0.0.4_374.43_2-23E3j9527.trx
44fae0aa12d3a6a885d883685cfddd490169bf049e259422ade16e0a96c50e3d RT-N66U_3.0.0.4_374.43_2-23E3j9527.trx
I had actually never added the OpenVPN logging level to the gui......just add aHey, @john9527 Thanks for the new build of course. In the new release after upgrading to openvpn 2.4.0, the global logging level has been removed in the openvpn client page. Is it possible to add this option back?
And I assume these commits haven't been pushed to your branch yet?
verb 1
or whatever logging level you want to the custom config section.
It's controlled by the "vpn_loglevel" nvram setting. Default is 3, values are from 0 to 11 (looks like OpenVPN devs are Spinal Tap fans).
Sorry, but nothing changed in 23E1 to E3 connected with SSH....and i just finished a time when I was connecting regularly with SSH via OpenVPN server.after upgrade i cannot ssh to my remote rt-n16
ovpn and other remote services do work but ssh is KO - i think we already had this issue a few versions ago
I just double checked after setting Allow WAN access....and it worked without any problem (My neighbor is on a different ISP and let's me connect to his ISP for testing).ssh seems ok from lan but not from wan...strange...
Mar 16 05:48:26 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for d1ulmmr4d4i8j4.cloudfront.net
Mar 16 05:48:27 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for da2lh5cs8ikqj.cloudfront.net
Mar 16 05:50:23 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.pcmrace.com
Mar 16 05:50:25 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for i.ytimg.com
Mar 16 06:04:58 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.pcmrace.com
Mar 16 06:14:41 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.nfohump.com
Mar 16 06:17:01 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for cs.rin.ru
Mar 16 06:17:46 dnsmasq[544]: server 81.139.57.100#53: resp: 0x00 query failed for scaramonga.imgur.com
Mar 16 06:20:19 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for avencolony.com
Mar 16 06:21:23 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.componentsuk.co.uk
Mar 16 06:21:53 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.watercoolinguk.co.uk
Mar 16 06:21:54 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for code.instantcart.com
Mar 16 06:24:55 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.chilledpc.co.uk
Mar 16 06:27:14 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for images.nvidia.com
Mar 16 06:27:14 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for api.digitalriver.com
Mar 16 06:27:15 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for gethatch.com
Mar 16 06:27:15 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for i.ytimg.com
Mar 16 06:37:35 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.adobe.com
Mar 16 06:38:02 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for cs.rin.ru
Mar 16 07:46:42 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for 1fizorp.oloadcdn.net
Mar 16 07:46:56 dnsmasq[544]: server 81.139.57.100#53: resp: 0x00 query failed for www.googleapis.com
Mar 16 08:04:53 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for cdn2.alphr.com
Mar 16 08:18:59 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for s.youtube.com
Mar 16 08:22:35 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for q.ebaystatic.com
Mar 16 08:23:41 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for promotions.ebay.co.uk
Mar 16 08:25:01 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.yalldata.com
Mar 16 08:26:24 dnsmasq[544]: server 81.139.57.100#53: resp: 0x00 query failed for store.akamai.steamstatic.com
Mar 16 08:29:53 dnsmasq[544]: server 81.139.56.100#53: resp: 0x00 query failed for www.smallnetbuilder.com
Don't use 'Debug' as the syslog loglevel...I'm getting hundreds of these in log, I mean hundreds!! 23E1 firmware??
EDIT: Just as a reminder to everyone, you can use the Search box in the upper right hamd corner to search within a thread you have open.
actually the issue is that dropbear binds on lan address only even if "aalow access from wan" is ONI just double checked after setting Allow WAN access....and it worked without any problem (My neighbor is on a different ISP and let's me connect to his ISP for testing).
Are you using a DDNS for access? Maybe double check it's been updated correctly, or if your IP changed after the code upgrade, it may take a bit to propagate to the DNS servers.
currently i run an sslh in front so i can connect to the lan address and i can connect but maybe I can fix this.6552 admin 1200 S dropbear -p 192.168.1.1:8000 -a
Ahh....the non-standard config using sslh (had to look that one up)actually the issue is that dropbear binds on lan address only even if "aalow access from wan" is ON
from what i found my nvram is empty for:
"sshd_addr="
woh should I enter 0.0.0.0 here?
It all depends on when you looked and what options you set up (i.e. if you set up something that would automatically disable CTF). Sometimes the entry on the tools page requires a reboot to get in sync with the actual state.....the entry on the switch page will generally immediately reflect if you did something to disable CTF. Try and reboot and they should be in sync.@john9527 , is it normal that after a clean install and nvram erase, during my initial setup I could see from the "tools" page that CTF (only) was enabled, but on the switch config page, NAT acceleration was set to "Disabled" out of the box. I know you have different "levels" in CTF, but I figured if tools showed as enabled, I would have seen it set to level 1 or 2 at least.
Unless CTF is just On all the time as it causes no issues since there is no Trend Micro DPI engine in your builds...?
Welcome To SNBForums
