@john9527 , would you please provide a brief description of DNS handling for different combination of the following options:
  • VPN / "Accept DNS Configuration"
  • VPN /"WAN clients use WAN DNS Server (DoT unavailable)"
  • VPN / "Redirect Internet traffic"VPN / "Rules for routing client traffic through the tunnel"
  • WAN/ "DoT server access"
  • WAN/ "Enable DNSSEC support"
At the first look the combination of ("Accept DNS Configuration" == "DoT" && "WAN clients use WAN DNS Server (DoT unavailable)" == true) looks not clear.
Personally I have the following practical problem: there are relatively fast WAN and slow VPN that also provides slow but secure DNS (that resolves all requests internally). The local government blocks some sites (e.g. linkedin.com). The blocking is two-level: DNS MITM attack (stub address substitution) and IP. So the first solution that came to mind is to use VPN routing table with the list of blocking sites and a fast DoT server (Clowdflare seems fast according different tests). On practice there are some issues with this setup: several times I have observed incorrect rendering of the blocked pages (probably we have switched to the secondary non-DoT DNS while rendering). Of course I may forward all DNS traffic to the secure DNS server but it is noticeable slow. Manual switching to VPN interface and back just to access linkedin.com seems too much. Is there an elegant solution?
Anyway thanks for the fork (RT-AC66U).
Can some one tell me if the last release of this for helps people that having problems with google pixel phone or new ones like oneplus 6 and AC66 router, or N66 router? The problem is when we turn on wifi, these routers reboot itself. Only know method for resolve this is disable support for ipv6 on router (but here, its not work). Maybe a problem with driver for wifi module. I can confirm here with android OREO and PIE that reboots my router. More cases in https://productforums.google.com/forum/#!msg/phone-by-google/JW7fnzOPtDo/_cD_oj5lAAAJ
I have several devices with different android versions, 5.1.1, 7.1.2, 8.1 and 9.0, also ancient ipod touch 1G, asus P525 with windows mobile 6.5 and some junk HP notebook, and my AC66 not rebooting because of that
Have you tried john9527's LTS RMerlin fork for your out of support router?
It hasn't had Asus firmware updates for almost a year now.
This is happening with some especific devices, like google pixel and oneplus. Do you have it? More cases can be view in searches, but i found very few information about it
Running Oneplus 5t & 3t with the latest version of John's fork; no problem as you've described.
I would advise you to update your router to this firmware anyway, due to the features introduced.
Hello everyone I don't mean to high Jack this person post. But can some one direct me were I can download John's fork thank you
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
I made it! But no luck. Now my oneplus6 cant connect to router. Its stay at "obtain ip address"...
In other hand, router doesnt reboot, stay online
EDIT: Wait...its seems like ok now! Maybe the router had some time to put all things in place after the factory reset + update this fork. I cant say what is, but it waiting some time since this procedure. I dont understand mush of JSSF partition. Just follow the instructions for update, and after a time its seems ok now (~30 minutes).
Weel, stay testing. Thanks for while
Well, unhappy my AC66R reboots again, but this time AFTER enabled IPV6 function (as I say before, people in google link support mention this function must be disabled for router still ON).
For info, I will post my last logs of the router (before its reboots at 31 december):
I try to stay connected on notebook and phone. If just notebook is ON by wifi, its normal. When turned ON wifi on my OP6... router reboot, as some people reported in searchs.
Mar 18 23:32:16 rc_service: ntp 663:notify_rc restart_upnp
Mar 18 23:32:16 miniupnpd[662]: shutting down MiniUPnPd
Mar 18 23:32:16 rc_service: ntp 663:notify_rc restart_diskmon
Mar 18 23:32:16 ntp: NTP update successful after 1 attempt(s)
Mar 18 23:32:16 disk_monitor: be idle
Mar 18 23:32:16 miniupnpd[672]: HTTP listening on port 33386
Mar 18 23:32:16 miniupnpd[672]: Listening for NAT-PMP/PCP traffic on port 5351
Mar 18 23:32:16 ddns_update: request successful
Mar 18 23:32:16 ddns_update: asusddns_update: 0
Mar 18 23:32:16 ddns: ddns update ok
Mar 18 23:32:16 dhcp_client: bound 189.6.135.69 via 189.6.128.1 during 10800 seconds.
Mar 18 23:32:46 crond[328]: time disparity of 4318708 minutes detected
Mar 18 23:32:47 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 64:a2:xx:xx:xx:xx
Mar 18 23:32:47 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:32:47 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:32:47 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:35:02 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 00:1a:xx:xx:xx:xx
Mar 18 23:35:02 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.127 00:1a:xx:xx:xx:xx
Mar 18 23:35:02 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.103 00:1a:xx:xx:xx:xx
Mar 18 23:35:02 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.103 00:1a:xx:xx:xx:xx
Mar 18 23:35:02 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.103 00:1a:xx:xx:xx:xx
Mar 18 23:37:05 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 64:a2:xx:xx:xx:xx
Mar 18 23:37:05 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:37:05 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:37:05 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.154 64:a2:xx:xx:xx:xx OnePlus_6
Mar 18 23:38:20 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.7 e4:42:xx:xx:xx:xx
Mar 18 23:38:20 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.7 e4:42:xx:xx:xx:xx AcerVX5
Mar 18 23:39:08 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 64:a2:xx:xx:xx:xx
Mar 18 23:39:08 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:39:08 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:39:08 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.154 64:a2:xx:xx:xx:xx OnePlus_6
Mar 18 23:40:22 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 64:a2:xx:xx:xx:xx
Mar 18 23:40:22 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:40:23 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:40:23 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.154 64:a2:xx:xx:xx:xx OnePlus_6
Mar 18 23:41:37 dnsmasq-dhcp[325]: DHCPDISCOVER(br0) 64:a2:xx:xx:xx:xx
Mar 18 23:41:37 dnsmasq-dhcp[325]: DHCPOFFER(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:41:37 dnsmasq-dhcp[325]: DHCPREQUEST(br0) 192.168.1.154 64:a2:xx:xx:xx:xx
Mar 18 23:41:37 dnsmasq-dhcp[325]: DHCPACK(br0) 192.168.1.154 64:a2:xx:xx:xx:xx OnePlus_6
Mar 18 23:47:06 rc_service: httpd 326:notify_rc reboot
Mar 18 23:47:09 dnsmasq[325]: exiting on receipt of SIGTERM
Mar 18 23:47:09 wan6: wan6 interface eth0 is down
Mar 18 23:47:09 miniupnpd[672]: shutting down MiniUPnPd
Mar 18 23:47:09 stop_wan(): perform DHCP release
Mar 18 23:47:09 kernel: Attempt to kill tasklet from interrupt
Mar 18 23:47:09 kernel: br0: port 1(vlan1) entering disabled state
Mar 18 23:47:09 kernel: br0: port 1(vlan1) entering listening state
Mar 18 23:47:09 kernel: br0: port 1(vlan1) entering learning state
Mar 18 23:47:09 kernel: br0: topology change detected, propagating
Mar 18 23:47:09 kernel: br0: port 1(vlan1) entering forwarding state
Mar 18 23:47:10 NFS_Server: daemon is stopped
Mar 18 23:47:10 MediaServer: daemon is stopped
Mar 18 23:47:10 FTP_Server: daemon is stopped
Mar 18 23:47:10 Samba_Server: smb daemon is stopped
Mar 18 23:47:10 WEBDAV_Server: daemon is stopped
Mar 18 23:47:14 WAN_Connection: ISP's DHCP did not function properly.
Mar 18 23:47:14 DualWAN: skip single wan wan_led_control - WANRED off
Mar 18 23:47:14 stop_nat_rules: apply the redirect_rules!
Mar 18 23:47:14 stop_nat_rules: (/tmp/redirect_rules) success!
Mar 18 23:47:14 kernel: usbcore: deregistering interface driver cdc_ncm
Mar 18 23:47:14 kernel: usbcore: deregistering interface driver rndis_host
Mar 18 23:47:14 kernel: usbcore: deregistering interface driver cdc_ether
Mar 18 23:47:14 kernel: usbcore: deregistering interface driver asix
Mar 18 23:47:14 kernel: usbcore: deregistering interface driver usblp
Mar 18 23:47:14 WEBDAV_Server: daemon is stopped
Mar 18 23:47:14 NFS_Server: daemon is stopped
Mar 18 23:47:14 MediaServer: daemon is stopped
Mar 18 23:47:14 FTP_Server: daemon is stopped
Mar 18 23:47:14 Samba_Server: smb daemon is stopped
Mar 18 23:47:15 stubby-proxy: stop stubby
Mar 18 23:47:16 watchdog02: no watchdog, restarting
Mar 18 23:47:17 haveged: haveged: Stopping due to signal 15
Mar 18 23:47:17 kernel: br0: port 3(eth2) entering disabled state
Mar 18 23:47:17 kernel: br0: port 2(eth1) entering disabled state
Mar 18 23:47:17 kernel: br0: port 1(vlan1) entering disabled state
Mar 18 23:47:17 kernel: vlan1: dev_set_promiscuity(master, -1)
Mar 18 23:47:17 kernel: device vlan1 left promiscuous mode
Mar 18 23:47:17 kernel: device eth1 left promiscuous mode
Mar 18 23:47:17 kernel: device eth2 left promiscuous mode
Mar 18 23:47:18 NFS_Server: daemon is stopped
Mar 18 23:47:18 MediaServer: daemon is stopped
Mar 18 23:47:18 FTP_Server: daemon is stopped
Mar 18 23:47:18 Samba_Server: smb daemon is stopped
Dec 31 22:00:12 syslogd started: BusyBox v1.25.1
Dec 31 22:00:12 kernel: klogd started: BusyBox v1.25.1 (2019-03-05 15:13:06 MST)
Dec 31 22:00:12 kernel: start_kernel
Dec 31 22:00:12 kernel: Linux version 2.6.22.19 (root@ASUS-AJ082535) (gcc version 4.2.3) #1 Tue Mar 5 15:13:58 MST 2019
Dec 31 22:00:12 kernel: CPU revision is: 00019749
Dec 31 22:00:12 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Dec 31 22:00:12 kernel: Determined physical RAM map:
Dec 31 22:00:12 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 22:00:12 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 22:00:12 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 22:00:12 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Dec 31 22:00:12 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 22:00:12 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 22:00:12 kernel: Synthesized TLB refill handler (20 instructions).
Dec 31 22:00:12 kernel: Synthesized TLB load handler fastpath (32 instructions).
Dec 31 22:00:12 kernel: Synthesized TLB store handler fastpath (32 instructions).
Dec 31 22:00:12 kernel: Synthesized TLB modify handler fastpath (31 instructions).
Dec 31 22:00:12 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 22:00:12 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 22:00:12 kernel: Using 300.000 MHz high precision timer.
Did you do a reset to factory defaults before flashing the LTS firmware? If you did, you need to do it again.
Did you use a new SSID on the router afterward? If not, you should change it to one with no special characters.
Did you 'forget' the network on your phone(s)? If not, you should do so, reboot the phone(s) and then re-associate with the router again.
Did you do a full reset network settings on the phone(s)? If not, you should do so.
See my signature for links to further info to fully reset your network and clients.
I didnt make all this steps yet, but will try this later. It seems like with tomato firm other people resolve this. Its sad, never imagine that will happen just because switch the phone, and i like this router...
https://www.reddit.com/r/GooglePixel/comments/9t0nh0/asus_routers_wifi_issues/
Just a quick note to all....
I'm not trying to ignore recent posts, but my father passed away this weekend and as you can imagine things are very hectic. I'll be back in a couple of weeks.
Sorry to read that John. Take care of yourself and your family.
Sad to hear that, please accept my condolences John.
