Updated to v0.8, everything seems fine. Thanks John for your terrific work![emoji1]
Wrong fork
in developing these thread: http://forums.smallnetbuilder.com/showthread.php?t=18142
branch https://github.com/AndreyPopovNew/asuswrt-merlin-rt-n/tree/rt-n
ftp://78.25.8.242/pub/ASUS/ASUSWRT_MODDED/
ftp://85.198.188.40/pub/ASUS/ASUSWRT_MODDED/
ftp://82.207.89.70/pub/ASUS/ASUSWRT_MODDED/
ftp://134.249.139.43/pub/ASUS/ASUSWRT_MODDED/
4MB flash routers:
- RT-N12 (not yet tested, no equipment)
- RT-N10D1 (not yet tested, no equipment)
+ RT-N10PV2 (tested)
8MB flash routers:
+RT-N10P (tested)
+ RT-N10U, RT-N10U B1 (tested)
+ RT-N12B1 (tested)
- RT-N12C1 (not yet tested, no equipment)
- RT-N12D1 (tested, with some wifi problems?)
- RT-N12HP (not yet tested, no equipment)
- RT-N12HP_B1 (not yet tested, no equipment)
- RT-N12_VP (not yet tested, no equipment)
+ RT-N15U (tested)
+ RT-N53 (tested)
16MB flash routers:
+ RT-N14UHP (tested, with some wifi problems?)
32MB flash routers:
+ RT-N16 (tested)
Changes:
- mod8 18.02.2015
- Based on Merlin 378.51 alpha (ASUS 3.0.0.4.378_4129) source
- add support to 4MB flash routers RT-N10D1, RT-N10PV2, RT-N12
a) DualWAN support
b) add PPTP VPN server and client
c) add SSH
d) Merlin Tools->Sysinfo & RunCmd
e) Merlin Wireless Survey
limitations:
() webui: some images low quality, some images removed
() webui: only English language
() no JFFS
() no CIFS - 5G support on RT-N53 now work!
- OpenVPN: if JFFS enable - store keys and certificates in JFFS. only one server and one client
- webui: Administration page - reworked swap options, add USB installed apps options
fixed (I hope): RT-N10U, RT-N53 not upgraded by webui
Is installing the Webkit (when available for a specific router) and the Webkit-ext optional or required?
webkit-ext.tgz downloaded and installed from web by prep-ext-kit.sh commandI saw your instructions for installing the external web kit, but I couldn't find the instruction for the -ext file, can you point me to it so I can add it to the wiki? (aka RT-N16_3.0.0.4_378_4129-gecc8142-m8-webkit-ext.tgz)?
Kernel support for IPsec is Merlin featureThe following is the list of feature that I gathered are unique to RT-N project based on your change log. Did I capture it correctly?
- Support for RT-N devices including the devices with smaller flash (limited features)
- Kernel support for IPSec
- OpenVPN support with JFFS cert/key storage
- SSH keys storage in JFFS (if JFFS enabled)
- Swap file management (if JFFS enabled)
also differences are:
- not default gateway option for PPTP client
Yes, you understand correctly with little exception:What I understand as this is the following:
With Asuswrt-merlin when the router is configured as a PPTP VPN client, all of the requests from systems on the local network are routed to the external PPTP VPN server. The routed requests to the external vpn server include requests for the internet (i.e. google, yahoo, youtube, facebook, etc). This routing may provide additional security if the local ISP link is not secure, but will add latency and bandwidth limitations. In the Asuswrt-Merlin-RT-N, when the router is configured as a PPTP VPN client, the VPN interface will no longer serve as the default gateway, and internet requests will not be sent to the external PPTP VPN server, instead the router will continue to route the local internet requests to the local ISP. The benefit of this feature is that you can securely link multiple LANs over PPTP VPN for the local network requests without degrading the performance of general internet requests.
- Did I understand this feature correctly?
- Is this for PPTP VPN only or does it apply to the OpenVPN VPN setup as well?
in RT-N fork you can choose use remote gateway as default or not!
OpenVPN has own options like - Redirect Internet traffic
it's two way:However, if pptp client is connected, the option usepeerdns (in /tmp/pptp.conf I think..) is always enforced and all LAN clients go thru remote endpoint (pptp server) DNS servers instead of the router DNS server.
Do you think there's any chance to implement a GUI knob to enable/disable pptp client use of peerdns?
Regards,
sk1z0fr3n1k
it's two way:
1. add in GUI new option and add new variable to nvram
2. always not use peerdns if not use remote gateway as default
agreeI think it makes sense to also disable usepeerdns if the user disables the remote gateway on pptp client config page.
yes. I hope next week.Do you think this could be implemented in future release of your firmware?
agree
any changes to ASUS dualwan codes.Would this firmwares dual wan failover /w watchdog work better on my RT-N16?
It would be nice if there was also an option to auto start pptp client on boot..![]()
if I know RMerlin not touch ASUS dualwan code.Sorry what?
any = many?
but Auto-reconnect option exist!?!?!?!
like for me ,all work perfectly:I thought auto-reconnect option in GUI enabled persist & holdoff values in pptp client config file (in order to bring pptp connection on again after disconnect) and not to connect on boot.
like for all work perfectly:
I remote reboot router that connected by PPTP and after reboot it again connected.Mar 24 17:52:08 pptp[11311]: LCP terminated by peer (MPPE disabled)
Mar 24 17:52:08 pptp[11311]: Connect time 1532.3 minutes.
Mar 24 17:52:08 pptp[11311]: Sent 1014381536 bytes, received 15065778 bytes.
Mar 24 17:52:09 pptpd[11310]: CTRL: Client pppd TERM sending
Mar 24 17:52:09 pptp[11311]: Terminating on signal 15
Mar 24 17:52:09 pptpd[11310]: CTRL: Client pppd finish wait
Mar 24 17:52:11 pptp[11311]: Connection terminated.
Mar 24 17:52:11 pptp[11311]: Modem hangup
Mar 24 17:52:11 pptp[11311]: Exit.
Mar 24 17:52:11 pptpd[11310]: CTRL: Client 85.198.178.37 control connection finished
Mar 24 17:53:03 pptpd[16815]: CTRL: Client 85.198.171.69 control connection started
Mar 24 17:53:04 pptpd[16815]: CTRL: Starting call (launching pppd, opening GRE)
Mar 24 17:53:04 pptp[16816]: Plugin pptp.so loaded.
Mar 24 17:53:04 pptp[16816]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Mar 24 17:53:04 pptp[16816]: pppd 2.4.7 started by admin, uid 0
Mar 24 17:53:04 pptp[16816]: Using interface ppp10
Mar 24 17:53:04 pptp[16816]: Connect: ppp10 <--> pptp (85.198.171.69)
Mar 24 17:53:04 pptp[16816]: MPPC/MPPE 128-bit stateless compression
boost wifi tx power requeried some nvram variables modifications and cfe modifications.hi andrey,
i have a RT N12 D1 with 2 10dbi antennas as a repeater and i was looking for a way, if its possible, to overclock or boost the router tx power. did your firmware do that?
thanks
Welcome To SNBForums
