[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
Sorry for wasting your time. I already use wive-rtnl. I just thought, that with your firmware wifi will be faster.
GREAT news for RT-N53 owners!!!
like in proverb
there would be a blessing in disguise
ASUS release new firmware for all routers to close exploit.
I extract wl_high.ko drivers from RT-N53 3.0.0.4.376.3754 firmware and now 5G on my mod started and work!
pre-mod8 folder for try
The n10p got an update too.
like in proverb
Those are really great news!
Looking forward to hear again from you
pre-mod8 test build for 4Mb flash routers !!!!
RT-N10P_V2
RT-N10D1
RT-N10+
RT-N12
folder pre-mod8/4mb
please test!
aaaaaaand RT-N53 with new copiled 5G WiFi drivers!!!!
folder pre-mod8/N53 !!!!!!!
please test!
I flashed my N53 with pre-mod8 (g0630694) this morning, but the 5 GHz still doesn't work. I can only choose between channel 0 or Auto.
Will try the new build right away (g17195f4) and I'll let you know if it worked
EDIT: the new build works!!! Great work Andrey!
378.3762 not want to work with compiled 5G driver and I re-download it with prebuild driver.
but 378.3813 work with compiled 5G.
I'm very glad.
pre-mod8 378.3873 with compiled wifi drivers (not prebuild)
also contain fix for ASUS security hole
RT-N53 (tested) with 5G WiFi driver pre-mod8/RT-N53 folder
4Mb flash routers pre-mod8/4Mb folder:
RT-N12
RT-N10D1
RT-N10PV2 (tested)
only English webui
features added to stock fimware
DualWan
VPN Server (PPTP) and Client (PPTP/L2TP)
Merlin Wireless Survey page
Merlin Sysinfo page
Merlin Run Command page
L7 protocols
IP Set
Working on RT-N16
It worked after second flash.
Did you have removed de OpenVPN and SNMP stuff?
I can't seem to find them.
Otherwise than that, all the asp pages and links seem to work.
Sorry, I just read the github page, and it is clear now.
yes, OpenVPN and SNMP temporary removed from all all builds because:
SNMP require some OpenVPN components
new OpenVPN server and clietns put large amounts of variables to NVRAM.
even after Restore to Factory Default initial size of NVRAM with OpenVPN enabled is ~30k (total 32k)
I want find way to clear NVRAM from unused variables and/or store variables on jffs(or USB).
increase size of NVRAM partition ,I think, wrong way.
I've tried the version RT-N53_3.0.0.4_378_3873-g17195f4-m8 against a RT-n53 using only 2.4Mhz but I've reverted back to the Shabby Tomato due to the fact that port forwarding is not working.
When do you expect to have a more complete and stable version ?
Also I've tried to launch the SSH daemon for "iptables -L" command execution but didn't work to enable it from the graphical interface so at the end I've executed the command directly in the web interface. And in this way I've realized that the port forward variables are not populated in the iptables output.
Thanks again
