Format JFFS partition at next boot
I think this no longer applies to newer firmwares. I do not see it on my AX86U, either.
Does this exist for the gt-axe16000.
See RMerlin's 2022 comment here about the format JFFS option missing on XT12, GT-AX6000, GT-AXE16000 and GT-AX11000_Pro:
These models don't use JFFS2, they use UBIFS for that partition, hence the option to format the JFFS2 partition is not there.
And when asked in 2024 about it missing on the AX86U, he responded:
It's never been there. These router uses the UBIFS filesystem, not JFFS. And since the router now stores a lot of its configuration there, erasing its content makes no sense unless you were doing a factory default reset.
The last router that used JFFS was the RT-AC5300.
