FQ-Codel not working well in practice - broken implementation ?
I just changed from cable on a trial basis, feel like I'm starting over. Started out seeing alot of buffering and some "jerky" video. Quad9 vs CF didn't matter.
Trying adaptive qos now instead of bw limiting, which I had to use on cable, as I no longer have a data cap. Experimentation starts now...
Did you get the fresh jr script for adaptive QoS?
I have alot to learn in the script-adding department!
are you comfortable with the command line/terminal? do you know what that is?
the people around here who write the scripts generally make it pretty easy for you to use them, but getting to a command line is basic playground knowledge. Start there, then make sure you can SSH into your router.
(I hear Grace Slick on my internal soundtrack singing to me about pills and a white rabbit...)
