Fully working stock AC68P (FCC ID AC68UV2 ). Downloaded recommended latest Merlin RT-AC68U_384.6_0.zip. Installed from admin panel over ethernet. Reboot it. When it comes up I try to login via ethernet 192.168.1.1 and see the following page:
Problem is, neither WIFI indicator is lit up and no WIFI is being broadcast. I tried pressing the WIFI on/off button but WIFI doesn't turn on. I did a factory reset, same thing. Now I can't get into the router. Is there a different LAN IP it defaults to with latest Merlin? Have a feeling the v2 is different.
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-AC68P.
To access the settings of RT-AC68P, reconnect to the wireless network and use the updated IP address and port number.
