goCoax MoCA 2.5 adapter
I just setup 3 GoCoax Moca 2.5 ethernet adapters. I've got it all configured after many adjustments and headaches with them not wanting to talk to each other. I ended up using WPS security on all of them because I was running into an issue with my Xfinity XB7 modem/router. The XB7 router runs on MoCA 2.0, but it would send the internet traffic through Moca and reach the GoCoax adapters. I was ok with that until i noticed that the XB7 would cap my bandwidth to about 500mb/s of my 1GBit connection when getting internet through the Moca network.
Here is why i enabled security... I wanted to bypass not receiving internet from XB7 via Moca, but only to receive it via Ethernet from the modem to the GoCoax adapter. Thats where the security enabled WPS on each GoCoax device helped to keep things sorted since i had no other use to use other MoCA devices except for the GoCoax to talk with each other to receive ISP connection from the XB7 modem going into one of the GOCoax via ethernet and then distributing the ISP connection to all existing GoCoax devices on the MoCa network.
So how did that work for me? It worked great until it didn't work :( .. I've come to agreement that the XB7 still interferes somehow with the GoCoax adapters. I've noticed that if i disconnect the modem completely from the coax (no internet); the GoCoax devices behave accordingly. But, once i plug the XB7 modem back to get internet the GoCoax adapters become unstable.
*The longest uptime the GoCoax were stable in their connections was up to 1.5 days. Then I had to reboot each one of the GoCoax adapters to start working again.
The splitter from outside where the main comcast comes in with all the splits going to the destinations in the house has a POE filter along with a splitter that handles 5mhz-2.4Ghz
My concern is that the XB7 may be creating these issues and wondering if i need to adjust frequency band of the GoCoax to not get interference from the XB7.
Any guidance would be helpful so that i have consistency in my network. When it works, i get solid 3200-3500 in the PHY chart and my internet bandwidth reaches close to 940mbs download and 40mbs upload.
Thanks for any help you guys can offer. Much appreciated!!
Any reason you haven't just disabled MoCA on the XB7? Do you have other MoCA nodes besides the goCoax adapters? If not, you could also consider installing a MoCA filter on its input. What frequencies is the XB7 using for its Internet upstream/downstream connections?
So apparently comcast will not let you disable the MoCa from the XB7. They said they do not support troubleshooting of anything related to MoCa.
There is a place within the Admin of the modem/router settings to disable, but once you disable it, it comes back on automatically. The XB7 frequency is on D1 (1150 MHz). There is no way to change its frequency either. So, the only other MoCa devices I can think of is the 2 - X1 TV boxes we use in separate rooms. I have tested to see if they were conflicting, but that wasn't the case when i was troubleshooting. It was the XB7 most definitely that was causing the issues.
My next step is to try your MoCa filter option to add to the input of the XB7. I have a couple of those i can work with :)
If the filter doesn't work, do you think adjusting the frequencies on the GoCoax MoCa's would help? The GoCoax are set to its default LOF 1150
Thanks for your guidance!
Speculative: I'd think shifting the goCoax adapters to the upper frequency range, plus enabling MoCA privacy for the goCoax adapters, may help avoid the conflicts with the XB7, while allowing the XB7 to continue to function as the MoCA bridge for the X1 set-tops.
FYI... Just posted to another thread:
Yes, our products can support this. Our device can support MoCA D-band low, D-band high and D-band extend three configurations. By default, we enable all of them. It will setup a 5-channels connection, from 1125MHz to 1625MHz. We know that, many MSO use D-band low 1125MHz to 1225MHz to act as MoCA WAN. You can change our device to use D-band high only, from 1350MHz to 1675MHz, can build a 3-channels connection.​
You need to set your IP address manually to 192.168.254.1, subnet 255.255.255.0 because the adapter does not have DHCP server. Set your IP manually and the web admin page will load. The default IP of the device is 192.168.254.254. username is admin, password is gocoax. You can change the default password as you want.​
edit: p.s. As a late aside, I just came across a /r/HomeNetworking post over on reddit revealing what appears to be a Frontier-branded goCoax MoCA 2.5 adapter ...
... that, per the user, has a physical switch for setting the operational frequency range for the MoCA adapter, to allow for simple configuration between D-Low, D-High and full Extended Band D.
They are kind of different than the goCoax. They don't have a TV port for it. Instead there is switch for WAN, FULL, LAN where the TV coax port would be on the goCoax. Pretty cool that it can switch between wan and lan.
So my assumption is that the switch settings correspond to:
  • WAN = MoCA Band D-Low (1 channel only)
  • LAN = MoCA Band D-High (3 channels max)
  • FULL = "full" Extended Band D (5 channels)
... per the above goCoax support page FAQ entry.
Yes - just change default IP addresses on the GoCoax adapters to match your local LAN for easier access...
How exactly should IPs be setup on GoCoax nodes to avoid any network issues? e.g. I have 5 GoCoax nodes I setup a few days ago (set encryption, but left IP as default). Goal is to access each one on the network without changing PC IP and having to direct connect to it.
Can I set DHCP on each node and let my router (using eero) assign IPs to each one? And then assign static IPs in the router config?
Or should I assign them as static in the GoCoax portal?
Everything is working now, so I don’t want to mess it up. However, I want an easy way to check status of each node and be able to upgrade firmware without having to physically interact with each one.
Either should work but Reserved DHCP addresses would be more manageable, right?
Yes, I'd like reserved, but want to make sure that if the devices now have an IP address assigned on my network, that it won't impact their ability to delivering the connected network backbone for some reason. It's working REALLY well right now and don't want to degrade the experience for some unknown reason.
It won't. Leaving DHCP *on* and doing static reservations is best practice here.
I just did a home office installation with three GoCoax adapters for a customer via this method and all worked flawlessly. Just make sure you have solid RG6 in the walls and good quality splitters, with amplification if the runs are long enough, and all should be rock solid.
So you're saying I *should* have done this and not left as the default 192.168.254.254.
Is there a way to change this on each node without directly plugging into each one physically?
I just purchased two of these. I have RG6 in my house that runs from each room to a central splitter outside. I disconnected the two that goto the two rooms I want to connect and connected them with a Coax coupler. I don't know exactly how the cables are routed through the house but I'm guessing its under 100ft. So the gocoax pair is basically directly connected together via RG6 on the moca connector. There is nothing on the Tv connector.
PHY rates show around 3500
As a test, the ethernet goes directly from my laptop, to the gocoax mocas, to my router. I tried transfering a file between my laptop and a computer directly connected on the router and my speed is only around 240 Mbps. If I tried the exact same test via wifi, I can get 480 Mbps. (My wifi access point is connect to another port on my router.)
Instead of using my laptop, I tried connecting to another laptop and got the same results.
I'm not sure what else to try here. Is there anything to tweak in the configuration to get better speeds?
The phy rate looks right.
Try using iperf with parallel streams instead of file tranfer. The exact command is mentioned in several of the threads here. Should pop up in a search for iperf here.
Yes, I did see that when I read the thread. However, I also read comments that it is not a realistic way to measure speed since not all connections are parallel. In the end, this will be mostly be used for file transfers and streaming video. I did not mention it in my original post, but I did try transferring multiple files at once. The total speed never changed. Two files would go at approx 15MB/s, three files was around 9MB/s.
Here are my iperf results: I tried over moca and wifi as a comparison
MOCA:
iperf3.exe -P 5 -w 2M -c 172.17.17.19
Connecting to host 172.17.17.19, port 5201
[  4] local 172.17.17.13 port 49847 connected to 172.17.17.19 port 5201
[  6] local 172.17.17.13 port 49848 connected to 172.17.17.19 port 5201
[  8] local 172.17.17.13 port 49849 connected to 172.17.17.19 port 5201
[ 10] local 172.17.17.13 port 49850 connected to 172.17.17.19 port 5201
[ 12] local 172.17.17.13 port 49851 connected to 172.17.17.19 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  7.75 MBytes  64.8 Mbits/sec
[  6]   0.00-1.00   sec  7.12 MBytes  59.6 Mbits/sec
[  8]   0.00-1.00   sec  9.50 MBytes  79.5 Mbits/sec
[ 10]   0.00-1.00   sec  9.38 MBytes  78.4 Mbits/sec
[ 12]   0.00-1.00   sec  6.00 MBytes  50.2 Mbits/sec
[SUM]   0.00-1.00   sec  39.8 MBytes   333 Mbits/sec
[  4]   1.00-2.00   sec  6.12 MBytes  51.5 Mbits/sec
[  6]   1.00-2.00   sec  5.12 MBytes  43.1 Mbits/sec
[  8]   1.00-2.00   sec  5.75 MBytes  48.3 Mbits/sec
[ 10]   1.00-2.00   sec  10.0 MBytes  84.1 Mbits/sec
[ 12]   1.00-2.00   sec  4.38 MBytes  36.8 Mbits/sec
[SUM]   1.00-2.00   sec  31.4 MBytes   264 Mbits/sec
[  4]   2.00-3.01   sec  7.12 MBytes  59.5 Mbits/sec
[  6]   2.00-3.01   sec  5.25 MBytes  43.8 Mbits/sec
[  8]   2.00-3.01   sec  5.25 MBytes  43.8 Mbits/sec
[ 10]   2.00-3.01   sec  10.1 MBytes  84.5 Mbits/sec
[ 12]   2.00-3.01   sec  3.75 MBytes  31.3 Mbits/sec
[SUM]   2.00-3.01   sec  31.5 MBytes   263 Mbits/sec
[  4]   3.01-4.00   sec  8.25 MBytes  69.6 Mbits/sec
[  6]   3.01-4.00   sec  5.12 MBytes  43.2 Mbits/sec
[  8]   3.01-4.00   sec  7.12 MBytes  60.1 Mbits/sec
[ 10]   3.01-4.00   sec  10.5 MBytes  88.5 Mbits/sec
[ 12]   3.01-4.00   sec  3.00 MBytes  25.3 Mbits/sec
[SUM]   3.01-4.00   sec  34.0 MBytes   287 Mbits/sec
[  4]   4.00-5.00   sec  6.25 MBytes  52.3 Mbits/sec
[  6]   4.00-5.00   sec  7.50 MBytes  62.8 Mbits/sec
[  8]   4.00-5.00   sec  7.12 MBytes  59.7 Mbits/sec
[ 10]   4.00-5.00   sec  9.75 MBytes  81.6 Mbits/sec
[ 12]   4.00-5.00   sec  3.25 MBytes  27.2 Mbits/sec
[SUM]   4.00-5.00   sec  33.9 MBytes   284 Mbits/sec
[  4]   5.00-6.00   sec  7.38 MBytes  61.7 Mbits/sec
[  6]   5.00-6.00   sec  6.00 MBytes  50.2 Mbits/sec
[  8]   5.00-6.00   sec  7.25 MBytes  60.7 Mbits/sec
[ 10]   5.00-6.00   sec  9.62 MBytes  80.6 Mbits/sec
[ 12]   5.00-6.00   sec  3.38 MBytes  28.2 Mbits/sec
[SUM]   5.00-6.00   sec  33.6 MBytes   281 Mbits/sec
[  4]   6.00-7.00   sec  7.38 MBytes  62.1 Mbits/sec
[  6]   6.00-7.00   sec  4.25 MBytes  35.8 Mbits/sec
[  8]   6.00-7.00   sec  6.75 MBytes  56.8 Mbits/sec
[ 10]   6.00-7.00   sec  9.75 MBytes  82.1 Mbits/sec
[ 12]   6.00-7.00   sec  4.88 MBytes  41.1 Mbits/sec
[SUM]   6.00-7.00   sec  33.0 MBytes   278 Mbits/sec
[  4]   7.00-8.01   sec  7.12 MBytes  59.2 Mbits/sec
[  6]   7.00-8.01   sec  4.12 MBytes  34.3 Mbits/sec
[  8]   7.00-8.01   sec  6.62 MBytes  55.1 Mbits/sec
[ 10]   7.00-8.01   sec  9.62 MBytes  80.0 Mbits/sec
[ 12]   7.00-8.01   sec  4.62 MBytes  38.5 Mbits/sec
[SUM]   7.00-8.01   sec  32.1 MBytes   267 Mbits/sec
[  4]   8.01-9.00   sec  7.25 MBytes  61.3 Mbits/sec
[  6]   8.01-9.00   sec  4.12 MBytes  34.9 Mbits/sec
[  8]   8.01-9.00   sec  5.25 MBytes  44.4 Mbits/sec
[ 10]   8.01-9.00   sec  10.9 MBytes  91.9 Mbits/sec
[ 12]   8.01-9.00   sec  4.75 MBytes  40.1 Mbits/sec
[SUM]   8.01-9.00   sec  32.2 MBytes   272 Mbits/sec
[  4]   9.00-10.00  sec  7.12 MBytes  59.8 Mbits/sec
[  6]   9.00-10.00  sec  4.25 MBytes  35.7 Mbits/sec
[  8]   9.00-10.00  sec  5.38 MBytes  45.1 Mbits/sec
[ 10]   9.00-10.00  sec  11.2 MBytes  94.5 Mbits/sec
[ 12]   9.00-10.00  sec  4.88 MBytes  40.9 Mbits/sec
[SUM]   9.00-10.00  sec  32.9 MBytes   276 Mbits/sec
[  4]   0.00-10.00  sec  71.8 MBytes  60.2 Mbits/sec                  sender
[  4]   0.00-10.00  sec  70.1 MBytes  58.8 Mbits/sec                  receiver
[  6]   0.00-10.00  sec  52.9 MBytes  44.4 Mbits/sec                  sender
[  6]   0.00-10.00  sec  51.0 MBytes  42.8 Mbits/sec                  receiver
[  8]   0.00-10.00  sec  66.0 MBytes  55.4 Mbits/sec                  sender
[  8]   0.00-10.00  sec  64.2 MBytes  53.8 Mbits/sec                  receiver
[ 10]   0.00-10.00  sec   101 MBytes  84.6 Mbits/sec                  sender
[ 10]   0.00-10.00  sec  99.4 MBytes  83.4 Mbits/sec                  receiver
[ 12]   0.00-10.00  sec  42.9 MBytes  36.0 Mbits/sec                  sender
[ 12]   0.00-10.00  sec  41.1 MBytes  34.5 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec   334 MBytes   280 Mbits/sec                  sender
[SUM]   0.00-10.00  sec   326 MBytes   273 Mbits/sec                  receiver
WIFI:
[  4] local 172.17.17.21 port 59909 connected to 172.17.17.19 port 5201
[  6] local 172.17.17.21 port 59910 connected to 172.17.17.19 port 5201
[  8] local 172.17.17.21 port 59911 connected to 172.17.17.19 port 5201
[ 10] local 172.17.17.21 port 59912 connected to 172.17.17.19 port 5201
[ 12] local 172.17.17.21 port 59913 connected to 172.17.17.19 port 5201
[  4]   0.00-1.01   sec  16.6 MBytes   138 Mbits/sec
[  6]   0.00-1.01   sec  10.8 MBytes  89.3 Mbits/sec
[  8]   0.00-1.01   sec  11.8 MBytes  97.6 Mbits/sec
[ 10]   0.00-1.01   sec  9.12 MBytes  75.8 Mbits/sec
[ 12]   0.00-1.01   sec  12.5 MBytes   104 Mbits/sec
[SUM]   0.00-1.01   sec  60.8 MBytes   505 Mbits/sec
[  4]   1.01-2.00   sec  14.9 MBytes   126 Mbits/sec
[  6]   1.01-2.00   sec  7.25 MBytes  61.3 Mbits/sec
[  8]   1.01-2.00   sec  9.50 MBytes  80.3 Mbits/sec
[ 10]   1.01-2.00   sec  8.50 MBytes  71.9 Mbits/sec
[ 12]   1.01-2.00   sec  10.8 MBytes  90.9 Mbits/sec
[SUM]   1.01-2.00   sec  50.9 MBytes   430 Mbits/sec
[  4]   2.00-3.00   sec  17.1 MBytes   143 Mbits/sec
[  6]   2.00-3.00   sec  7.25 MBytes  60.7 Mbits/sec
[  8]   2.00-3.00   sec  8.88 MBytes  74.3 Mbits/sec
[ 10]   2.00-3.00   sec  9.00 MBytes  75.3 Mbits/sec
[ 12]   2.00-3.00   sec  11.2 MBytes  94.1 Mbits/sec
[SUM]   2.00-3.00   sec  53.5 MBytes   448 Mbits/sec
[  4]   3.00-4.01   sec  15.8 MBytes   132 Mbits/sec
[  6]   3.00-4.01   sec  8.12 MBytes  67.9 Mbits/sec
[  8]   3.00-4.01   sec  10.8 MBytes  89.8 Mbits/sec
[ 10]   3.00-4.01   sec  11.1 MBytes  92.9 Mbits/sec
[ 12]   3.00-4.01   sec  12.2 MBytes   102 Mbits/sec
[SUM]   3.00-4.01   sec  58.0 MBytes   484 Mbits/sec
[  4]   4.01-5.00   sec  14.0 MBytes   118 Mbits/sec
[  6]   4.01-5.00   sec  8.12 MBytes  68.7 Mbits/sec
[  8]   4.01-5.00   sec  11.0 MBytes  93.0 Mbits/sec
[ 10]   4.01-5.00   sec  12.0 MBytes   101 Mbits/sec
[ 12]   4.01-5.00   sec  13.2 MBytes   112 Mbits/sec
[SUM]   4.01-5.00   sec  58.4 MBytes   494 Mbits/sec
[  4]   5.00-6.00   sec  12.8 MBytes   107 Mbits/sec
[  6]   5.00-6.00   sec  8.00 MBytes  67.1 Mbits/sec
[  8]   5.00-6.00   sec  10.0 MBytes  83.8 Mbits/sec
[ 10]   5.00-6.00   sec  10.9 MBytes  91.2 Mbits/sec
[ 12]   5.00-6.00   sec  11.9 MBytes  99.6 Mbits/sec
[SUM]   5.00-6.00   sec  53.5 MBytes   449 Mbits/sec
[  4]   6.00-7.00   sec  11.6 MBytes  97.5 Mbits/sec
[  6]   6.00-7.00   sec  7.88 MBytes  66.0 Mbits/sec
[  8]   6.00-7.00   sec  10.6 MBytes  89.1 Mbits/sec
[ 10]   6.00-7.00   sec  11.5 MBytes  96.4 Mbits/sec
[ 12]   6.00-7.00   sec  11.6 MBytes  97.5 Mbits/sec
[SUM]   6.00-7.00   sec  53.2 MBytes   447 Mbits/sec
[  4]   7.00-8.00   sec  11.6 MBytes  97.2 Mbits/sec
[  6]   7.00-8.00   sec  7.88 MBytes  65.8 Mbits/sec
[  8]   7.00-8.00   sec  10.5 MBytes  87.8 Mbits/sec
[ 10]   7.00-8.00   sec  11.4 MBytes  95.1 Mbits/sec
[ 12]   7.00-8.00   sec  10.8 MBytes  89.9 Mbits/sec
[SUM]   7.00-8.00   sec  52.1 MBytes   436 Mbits/sec
[  4]   8.00-9.00   sec  10.8 MBytes  90.5 Mbits/sec
[  6]   8.00-9.00   sec  8.38 MBytes  70.5 Mbits/sec
[  8]   8.00-9.00   sec  10.8 MBytes  90.5 Mbits/sec
[ 10]   8.00-9.00   sec  10.6 MBytes  89.4 Mbits/sec
[ 12]   8.00-9.00   sec  11.4 MBytes  95.8 Mbits/sec
[SUM]   8.00-9.00   sec  51.9 MBytes   437 Mbits/sec
[  4]   9.00-10.01  sec  11.4 MBytes  94.8 Mbits/sec
[  6]   9.00-10.01  sec  9.25 MBytes  77.1 Mbits/sec
[  8]   9.00-10.01  sec  11.2 MBytes  93.7 Mbits/sec
[ 10]   9.00-10.01  sec  11.5 MBytes  95.8 Mbits/sec
[ 12]   9.00-10.01  sec  11.2 MBytes  93.7 Mbits/sec
[SUM]   9.00-10.01  sec  54.6 MBytes   455 Mbits/sec
[  4]   0.00-10.01  sec   136 MBytes   114 Mbits/sec                  sender
[  4]   0.00-10.01  sec   136 MBytes   114 Mbits/sec                  receiver
[  6]   0.00-10.01  sec  82.9 MBytes  69.5 Mbits/sec                  sender
[  6]   0.00-10.01  sec  82.6 MBytes  69.2 Mbits/sec                  receiver
[  8]   0.00-10.01  sec   105 MBytes  88.0 Mbits/sec                  sender
[  8]   0.00-10.01  sec   105 MBytes  88.0 Mbits/sec                  receiver
[ 10]   0.00-10.01  sec   106 MBytes  88.5 Mbits/sec                  sender
[ 10]   0.00-10.01  sec   106 MBytes  88.5 Mbits/sec                  receiver
[ 12]   0.00-10.01  sec   117 MBytes  98.0 Mbits/sec                  sender
[ 12]   0.00-10.01  sec   117 MBytes  98.0 Mbits/sec                  receiver
[SUM]   0.00-10.01  sec   547 MBytes   458 Mbits/sec                  sender
[SUM]   0.00-10.01  sec   547 MBytes   458 Mbits/sec                  receiver
MOCA:
Curious that the iPerf results match your file transfer results. Makes me wonder about your Ethernet NICs on the source/target sides of the test, given the PHY rates look good.
Well the "target" NIC is the same for both tests and connects through my ER-X router (which has the WIFI AP connect to it so that can't be the bottleneck.
I tried connecting the laptop directly into the router and here is what I get:
[  4] local 172.17.17.13 port 62915 connected to 172.17.17.19 port 5201
[  6] local 172.17.17.13 port 62916 connected to 172.17.17.19 port 5201
[  8] local 172.17.17.13 port 62917 connected to 172.17.17.19 port 5201
[ 10] local 172.17.17.13 port 62918 connected to 172.17.17.19 port 5201
[ 12] local 172.17.17.13 port 62919 connected to 172.17.17.19 port 5201
[  4]   0.00-1.00   sec  17.5 MBytes   147 Mbits/sec
[  6]   0.00-1.00   sec  17.4 MBytes   146 Mbits/sec
[  8]   0.00-1.00   sec  5.25 MBytes  44.0 Mbits/sec
[ 10]   0.00-1.00   sec  7.12 MBytes  59.7 Mbits/sec
[ 12]   0.00-1.00   sec  6.38 MBytes  53.4 Mbits/sec
[SUM]   0.00-1.00   sec  53.6 MBytes   450 Mbits/sec
[  4]   1.00-2.00   sec  16.5 MBytes   138 Mbits/sec
[  6]   1.00-2.00   sec  16.4 MBytes   137 Mbits/sec
[  8]   1.00-2.00   sec  4.50 MBytes  37.7 Mbits/sec
[ 10]   1.00-2.00   sec  5.88 MBytes  49.2 Mbits/sec
[ 12]   1.00-2.00   sec  4.12 MBytes  34.6 Mbits/sec
[SUM]   1.00-2.00   sec  47.4 MBytes   397 Mbits/sec
[  4]   2.00-3.01   sec  16.5 MBytes   138 Mbits/sec
[  6]   2.00-3.01   sec  16.4 MBytes   137 Mbits/sec
[  8]   2.00-3.01   sec  5.38 MBytes  44.9 Mbits/sec
[ 10]   2.00-3.01   sec  5.12 MBytes  42.8 Mbits/sec
[ 12]   2.00-3.01   sec  4.50 MBytes  37.6 Mbits/sec
[SUM]   2.00-3.01   sec  47.9 MBytes   400 Mbits/sec
[  4]   3.01-4.00   sec  16.5 MBytes   139 Mbits/sec
[  6]   3.01-4.00   sec  16.2 MBytes   137 Mbits/sec
[  8]   3.01-4.00   sec  5.12 MBytes  43.2 Mbits/sec
[ 10]   3.01-4.00   sec  4.25 MBytes  35.8 Mbits/sec
[ 12]   3.01-4.00   sec  4.62 MBytes  39.0 Mbits/sec
[SUM]   3.01-4.00   sec  46.8 MBytes   394 Mbits/sec
[  4]   4.00-5.00   sec  16.1 MBytes   135 Mbits/sec
[  6]   4.00-5.00   sec  16.1 MBytes   135 Mbits/sec
[  8]   4.00-5.00   sec  5.38 MBytes  45.0 Mbits/sec
[ 10]   4.00-5.00   sec  4.38 MBytes  36.6 Mbits/sec
[ 12]   4.00-5.00   sec  4.25 MBytes  35.6 Mbits/sec
[SUM]   4.00-5.00   sec  46.2 MBytes   387 Mbits/sec
[  4]   5.00-6.00   sec  16.5 MBytes   138 Mbits/sec
[  6]   5.00-6.00   sec  16.2 MBytes   136 Mbits/sec
[  8]   5.00-6.00   sec  6.38 MBytes  53.3 Mbits/sec
[ 10]   5.00-6.00   sec  4.62 MBytes  38.7 Mbits/sec
[ 12]   5.00-6.00   sec  3.75 MBytes  31.4 Mbits/sec
[SUM]   5.00-6.00   sec  47.5 MBytes   397 Mbits/sec
[  4]   6.00-7.00   sec  15.6 MBytes   132 Mbits/sec
[  6]   6.00-7.00   sec  15.0 MBytes   126 Mbits/sec
[  8]   6.00-7.00   sec  5.25 MBytes  44.2 Mbits/sec
[ 10]   6.00-7.00   sec  4.00 MBytes  33.7 Mbits/sec
[ 12]   6.00-7.00   sec  3.38 MBytes  28.4 Mbits/sec
[SUM]   6.00-7.00   sec  43.2 MBytes   364 Mbits/sec
[  4]   7.00-8.01   sec  15.9 MBytes   132 Mbits/sec
[  6]   7.00-8.01   sec  15.2 MBytes   127 Mbits/sec
[  8]   7.00-8.01   sec  5.38 MBytes  44.7 Mbits/sec
[ 10]   7.00-8.01   sec  4.12 MBytes  34.3 Mbits/sec
[ 12]   7.00-8.01   sec  3.25 MBytes  27.0 Mbits/sec
[SUM]   7.00-8.01   sec  43.9 MBytes   365 Mbits/sec
[  4]   8.01-9.00   sec  16.1 MBytes   136 Mbits/sec
[  6]   8.01-9.00   sec  16.1 MBytes   136 Mbits/sec
[  8]   8.01-9.00   sec  4.88 MBytes  41.1 Mbits/sec
[ 10]   8.01-9.00   sec  3.75 MBytes  31.6 Mbits/sec
[ 12]   8.01-9.00   sec  3.50 MBytes  29.5 Mbits/sec
[SUM]   8.01-9.00   sec  44.4 MBytes   374 Mbits/sec
[  4]   9.00-10.00  sec  15.9 MBytes   134 Mbits/sec
[  6]   9.00-10.00  sec  16.0 MBytes   135 Mbits/sec
[  8]   9.00-10.00  sec  4.62 MBytes  38.9 Mbits/sec
[ 10]   9.00-10.00  sec  4.38 MBytes  36.8 Mbits/sec
[ 12]   9.00-10.00  sec  3.62 MBytes  30.5 Mbits/sec
[SUM]   9.00-10.00  sec  44.5 MBytes   374 Mbits/sec
[  4]   0.00-10.00  sec   163 MBytes   137 Mbits/sec                  sender
[  4]   0.00-10.00  sec   162 MBytes   136 Mbits/sec                  receiver
[  6]   0.00-10.00  sec   161 MBytes   135 Mbits/sec                  sender
[  6]   0.00-10.00  sec   160 MBytes   134 Mbits/sec                  receiver
[  8]   0.00-10.00  sec  52.1 MBytes  43.7 Mbits/sec                  sender
[  8]   0.00-10.00  sec  50.7 MBytes  42.5 Mbits/sec                  receiver
[ 10]   0.00-10.00  sec  47.6 MBytes  39.9 Mbits/sec                  sender
[ 10]   0.00-10.00  sec  45.9 MBytes  38.5 Mbits/sec                  receiver
[ 12]   0.00-10.00  sec  41.4 MBytes  34.7 Mbits/sec                  sender
[ 12]   0.00-10.00  sec  39.9 MBytes  33.5 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec   465 MBytes   390 Mbits/sec                  sender
[SUM]   0.00-10.00  sec   459 MBytes   385 Mbits/sec                  receiver
