Got Gigabit? Nope :-(
BigAl.nz
Hi All,
I have a samsung QX410 laptop with Marvell 88E8059 chipset for Gigabit ethernet, yet when I plug into my switch I only get 100Mb.
Now I am sure my hardware is good because I get Gigabit in Safe mode and I get gigabit if I boot Ubuntu Live CD etc.
I have tried using msconfig to disable all non microsoft services but that didnt help.
Safe mode appears to use the same driver as non safe mode.
Does anyone know how to diagnose this further? Its very annoying.
Here are the adapters if that helps:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Al>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
Wireless LAN adapter Wireless Network Connection:
   Link-local IPv6 Address . . . . . : fe80::7d2f:63ab:2c77:4f7e%12
   IPv4 Address. . . . . . . . . . . : 192.168.15.101
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.15.1
Tunnel adapter isatap.{E0420A95-EF64-4161-8C0C-6960752270C7}:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Tunnel adapter isatap.{15A221A2-78F0-4E30-B2EE-BA280831F966}:
C:\Users\Al>
And here is a link to my autoruns :
https://www.dropbox.com/s/v2j5ixr6hfkjqo2/AutoRuns.txt
Cheers in advance,
-Al
that screen dump - is when you were using WiFi. It says the ethernet port is disconnected.
from your other symptoms.. a guess is that the device driver for the Ethernet NIC is hosed up. So uninstall, reinstall. If it's working - use Device Manager properties to check up updates.
Do Windows update too.
Yes I was using wifi. I guess I wondered if any of those adapters might be interferring somehow.
Re the driver, I have tried several versions, both from Samsung and directly from Marvell. No joy there.
Cheers
-Al
