camarolt1guy
I have a GT-AX11000 running merlin 3004.388.2_2rog and for the last week its been randomly dropping all connections. sometimes they come back and sometimes i have to reboot the router. After that it could be fine for 5 minutes or 5 hours. its just completly random. heres the error logs from yesterday. I dont know why some say may 5th. I also dont know what level of logs are needed to help diagonose this problem. Emergency, Critical, Error, warning or any of the other ones. Thanks in advance.
May 5 00:05:12 wsdd2[1380]: starting.
May 5 00:05:12 jffs2: valid logs(1)
May 5 00:05:13 lldpd[1398]: could not open either /etc/os-release or /usr/lib/os-release
May 5 00:05:13 lldpd[1398]: lsb_release information not available
May 5 00:05:13 lldpd[1402]: created chroot directory /var/run/lldpd
May 5 00:05:13 lldpd[1402]: /etc/localtime copied to chroot
May 5 00:05:13 lldpd[1402]: protocol LLDP enabled
May 5 00:05:13 lldpd[1402]: protocol CDPv1 disabled
May 5 00:05:13 lldpd[1402]: protocol CDPv2 disabled
May 5 00:05:13 lldpd[1402]: protocol SONMP disabled
May 5 00:05:13 lldpd[1402]: protocol EDP disabled
May 5 00:05:13 lldpd[1402]: protocol FDP disabled
May 5 00:05:13 lldpd[1402]: libevent 2.0.21-stable initialized with epoll method
May 5 00:05:13 networkmap: Error locking /var/lock//usr/networkmap/nmp_conv_type.js.lock: 2 No such file or directory
May 5 00:05:13 networkmap: Error unlocking -1: 9 Bad file descriptor
May 5 00:05:13 networkmap: Error locking /var/lock//usr/networkmap/nmp_vendor_type.js.lock: 2 No such file or directory
May 5 00:05:13 networkmap: Error locking /var/lock//usr/networkmap/nmp_bwdpi_type.js.lock: 2 No such file or directory
May 5 00:05:13 lldpd[1402]: cannot get ethtool link information with GLINKSETTINGS (requires 4.9+): Operation not permitted
May 5 00:05:13 lldpcli[1399]: lldpd should resume operations
May 5 00:05:13 avahi-daemon[1233]: Server startup complete. Host name is GT-AX11000-E3A0.local. Local service cookie is 1326380532.
May 5 00:05:13 avahi-daemon[1233]: Alias name "GT-AX11000" successfully established.
May 5 00:05:13 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 00:05:13 kernel: usb 3-1: new high-speed USB device number 3 using ehci-platform
May 5 00:05:13 kernel: cfg80211: Calling CRDA to update world regulatory domain
May 5 00:05:14 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 00:05:14 WAN(0)_Connection: WAN(0) link down.
May 5 00:05:14 avahi-daemon[1233]: Service "GT-AX11000-E3A0" (/tmp/avahi/services/alexa.service) successfully established.
May 5 00:05:14 dnsmasq-dhcp[1208]: DHCPREQUEST(br0) 192.168.50.71 fc:65:de:2b:fe:09
May 5 00:05:14 dnsmasq-dhcp[1208]: DHCPACK(br0) 192.168.50.71 fc:65:de:2b:fe:09 amazon-144df21be
May 5 00:05:14 dnsmasq-script[1208]: json_object_from_file: error opening file /jffs/nmp_vc_json.js: No such file or directory
May 5 00:05:14 kernel: usb 3-1: new high-speed USB device number 4 using ehci-platform
May 5 00:05:14 kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
May 5 00:05:14 kernel: xhci-hcd xhci-hcd.0: Cannot set link state.
May 5 00:05:14 kernel: usb usb2-port1: cannot disable (err = -32)
May 5 00:05:14 dnsmasq-dhcp[1208]: DHCPREQUEST(br0) 192.168.50.232 4c:3b:df:67:28:2d
May 5 00:05:14 dnsmasq-dhcp[1208]: DHCPACK(br0) 192.168.50.232 4c:3b:df:67:28:2d XBOX
May 5 00:05:15 wlceventd: wlceventd_proc_event(685): eth8: Auth 90:39:5F:B0:A4:52, status: Successful (0), rssi:0
May 5 00:05:15 wlceventd: wlceventd_proc_event(722): eth8: Assoc 90:39:5F:B0:A4:52, status: Successful (0), rssi:-39
May 5 00:05:15 hostapd: eth8: STA 90:39:5f:b0:a4:52 IEEE 802.11: associated
May 5 00:05:15 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 5 00:05:15 hostapd: eth8: STA 90:39:5f:b0:a4:52 RADIUS: starting accounting session DFDD6E63A11EF1E3
May 5 00:05:15 hostapd: eth8: STA 90:39:5f:b0:a4:52 WPA: pairwise key handshake completed (RSN)
May 5 00:05:15 dnsmasq-dhcp[1208]: DHCPREQUEST(br0) 192.168.50.61 90:39:5f:b0:a4:52
May 5 00:05:15 dnsmasq-dhcp[1208]: DHCPACK(br0) 192.168.50.61 90:39:5f:b0:a4:52
May 5 00:05:15 dnsmasq-script[1208]: connect error: No such file or directory
May 5 00:05:15 dnsmasq-script[1208]: [SEND_AMAS_NODE_EVENT:(95)] ERROR connecting:No such file or directory.
May 5 00:05:15 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 00:05:15 kernel: wireguard: WireGuard 1.0.20220627 loaded. See www.wireguard.com for information.
May 5 00:05:15 kernel: wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
May 5 00:05:15 wsdd2[1380]: 'Terminated' signal received.
May 5 00:05:15 wsdd2[1380]: terminating.
May 5 00:05:15 Samba_Server: smb daemon is stopped
May 5 00:05:15 Samba_Server: daemon is started
May 5 00:05:15 WireGuard: Starting server.
May 5 00:05:15 wsdd2[1532]: starting.
May 5 00:05:15 dropbear[1537]: Running in background
May 5 00:05:15 dnsmasq[1208]: read /etc/hosts - 22 names
May 5 00:05:15 dnsmasq[1208]: using nameserver 8.8.8.8#53
May 5 00:05:15 dnsmasq[1208]: using nameserver 8.8.4.4#53
May 5 00:05:15 kernel: SCSI subsystem initialized
May 5 00:05:15 acsd: eth6: selected channel spec: 0x1004 (4)
May 5 00:05:15 acsd: eth6: Adjusted channel spec: 0x1004 (4)
May 5 00:05:15 acsd: acs_set_chspec: 0x1004 (4) for reason APCS_INIT
May 5 00:05:15 kernel: usbcore: registered new interface driver usb-storage
May 5 00:05:15 kernel: usbcore: registered new interface driver uas
May 5 00:05:15 kernel: tfat: loading out-of-tree module taints kernel.
May 5 00:05:15 kernel: Tuxera FAT 12/16/32 driver version 3017.7.24.32 [Flags: R/W MODULE].
May 5 00:05:15 kernel: Built against headers 4.1.51 #4 SMP PREEMPT Wed Nov 21 11:14:51 CST 2018 arm64
May 5 00:05:15 kernel: Running on kernel 4.1.51 #4 SMP PREEMPT Wed Jul 31 20:57:41 EDT 2024 aarch64
May 5 00:05:15 kernel: usb 3-1: new high-speed USB device number 5 using ehci-platform
May 5 00:05:15 acsd: eth7: Selecting 5g band ACS policy
May 5 00:05:15 kernel: Tuxera NTFS driver 3018.6.22d [Flags: R/W MODULE].
May 5 00:05:15 kernel: Tuxera HFS+ driver 3020.11.30d
May 5 00:05:15 kernel: init (1): drop_caches: 1
May 5 00:05:15 : fwver: 3.0.0.4_388.8_2_rog (sn: /ha:D4:5D:64:EB:E3:A0 )
May 5 00:05:16 kernel: usb-storage 3-1:1.0: USB Mass Storage device detected
May 5 00:05:16 kernel: scsi host0: usb-storage 3-1:1.0
May 5 00:05:16 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 00:05:16 kernel: cfg80211: Calling CRDA to update world regulatory domain
May 5 00:05:16 acsd: eth7: selected channel spec: 0xe12a (40/80)
May 5 00:05:16 acsd: eth7: Adjusted channel spec: 0xe12a (40/80)
May 5 00:05:16 acsd: acs_set_chspec: 0xe12a (40/80) for reason APCS_INIT
May 5 00:05:17 kernel: scsi 0:0:0:0: Direct-Access StoreJet Transcend 0 PQ: 0 ANSI: 6
May 5 00:05:17 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
May 5 00:05:17 kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
May 5 00:05:17 kernel: sd 0:0:0:0: [sda] Write Protect is off
May 5 00:05:17 kernel: sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
May 5 00:05:17 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 5 00:05:17 acsd: eth8: Selecting 5g band ACS policy
May 5 00:05:17 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 00:05:17 kernel: xhci-hcd xhci-hcd.0: Cannot set link state.
May 5 00:05:17 kernel: usb usb2-port1: cannot disable (err = -32)
May 5 00:05:17 kernel: sda: sda1
May 5 00:05:17 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
May 5 00:05:18 wlceventd: wlceventd_proc_event(685): eth6: Auth FC:65:DE:2B:FE:09, status: Successful (0), rssi:0
May 5 00:05:18 kernel: random: nonblocking pool is initialized
May 5 00:05:18 hostapd: eth6: STA fc:65:de:2b:fe:09 IEEE 802.11: associated
May 5 00:05:18 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 5 00:05:18 wlceventd: wlceventd_proc_event(722): eth6: Assoc FC:65:DE:2B:FE:09, status: Successful (0), rssi:-38
May 5 00:05:18 httpd: Succeed to init SSL certificate...8443
May 5 00:05:18 hostapd: eth6: STA fc:65:de:2b:fe:09 RADIUS: starting accounting session EBA6C286A9FFE620
May 5 00:05:18 hostapd: eth6: STA fc:65:de:2b:fe:09 WPA: pairwise key handshake completed (RSN)
May 5 00:05:18 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
May 5 00:05:19 kernel: cfg80211: Calling CRDA to update world regulatory domain
May 5 00:05:21 dnsmasq-dhcp[1208]: DHCPDISCOVER(br0) 76:b6:29:fd:86:28
May 5 00:05:21 dnsmasq-dhcp[1208]: DHCPOFFER(br0) 192.168.50.206 76:b6:29:fd:86:28
May 5 00:05:21 dnsmasq-dhcp[1208]: DHCPREQUEST(br0) 192.168.50.71 fc:65:de:2b:fe:09
