I wouldn't expect much changes to AiMesh. Keep in mind that to get the most out of Wifi 7, you want to be on the 6 GHz band, which would make a very poor choice for backhauling nodes due to its much shorter range.I'd be interested to find out what speeds can be expected with Aimesh with a couple of these. In a very old house with no hard wired option available this is very relevant to me.
As @RMerlin said, the 6GHz band is likely to not be too helpful to you. I also have an old house (WWI-vintage, thick oak floors, plaster-on-wood-lath interior walls) and I can detect a significant difference in signal penetration even between the lower and higher 5GHz bands. My Mac laptop usually reaches 1200 Mbps TX rate in my office, one floor above my AP, if it's running in the 36-48 channels; but in the 149-161 channels I rarely get better than 860 to 960 Mbps. 6GHz is going to be worse. I've done some preliminary experiments with 6E gear that suggest that the 6GHz band is basically going to give me only one-room coverage in this house. When I get to the point of being ready to buy such gear, I'm thinking of one low-power AP for the living room, another for the office, and the rest of the property will have to get by on 2.4 or 5GHz connectivity. That'll work fine for my computing habits, but if yours is a more spread-out lifestyle, you might have a problem.I'd be interested to find out what speeds can be expected with Aimesh with a couple of these. In a very old house with no hard wired option available this is very relevant to me.
Not trying to read to much into it, but I'm wondering if Asus is revising the specs on the GT-BE98
I think that WIFI 6E designation on the GT-BE98 is an error on Asus' part. Both are supposed to be Wifi 7 routers with the GT-BE98 being the flagship.Or dropping it entirely, maybe? It was always going to be a product for those who want the cutting edge, and if they have WiFi 7 gear available then 6E isn't cutting-edge anymore. They might be thinking now in terms of going straight to WiFi 7 (and you're right that the LAN ports on this were pretty lame, too).
A house of this vintage most likely has lead paint on the walls as well, so in effect each room is it's own obstacle.I also have an old house (WWI-vintage, thick oak floors, plaster-on-wood-lath interior walls) and I can detect a significant difference in signal penetration even between the lower and higher 5GHz bands.
Available:
Access Point nanoHD / U6 Lite Cover, 3-Pack
Custom encasing for the Access Point nanoHD or U6 Lite. The Access Point nanoHD Covers allow you to personalize the exterior of a UAP nanoHD or U6 Lite so it blends seamlessly with your space's aesthetic and equipment.store.ui.com
"Cheaper than ASUS" was never the sales argument for UbiquitiA friend of mine did his house in Ubiquiti, so I checked out their products. Very sleek, but otherwise nothing standout from what I can tell. Building a dispersed wifi 6 system will be at least as expensive as setting up two ASUS routers either as main/AP or mesh.
Don’t know what you mean about the pro models. Do the GT-AX11000 Pro and the GT-AXE16000 not meet your standards?It’s going to be at least 3-4 years for WIFI 7 to start to become main stream. Several of the clients I’ve bought in 2021 / 2022 still do not fully take advantage of WiFi 6 and the 160mhz band yet.
Asus just not releasing the WIFI 6 pro models says a lot. They are likely going to support them at least the next 5-6 years.
The key point with WiFi 7 routers is that all of them will come with multiple multi-gig ports.
The industry is at a key inflection point. Everyone with fiber GPONs is going to get access to affordable 10Gb service as competition ramps up.
Cable companies are already preparing for 10Gb service with DOCSIS 4.0 so they can still compete.
If you can get 1Gb for $50 but 10Gb is only $70, then you’re going to go for it. And you’re going to get new routers and switches that can take advantage of that speed. Many of the people who skipped Wifi6 and 6E will go directly to 7.
My point is that people are going to be needing those ports, and if the price difference is nominal, people are going to go for Wifi7.WIFI 7 is not needed for multi gig ports. My 88u Pro as two multi Gig ports. The 86u pro and ax6000 also have them. Then the 89x has a 10gig Ethernet and 10gig SFP.
Most people don’t need it, but they’ll get it because the price difference will be marginal. Going from Gb to 10Gb is very cost effective for fiber companies, and upping speeds is the easiest way to upsell and compete.Also, not many will ever need greater than 1 GIG for their ISP unless chasing a number. Heck, I’d argue most households do not really need anything above a 300/300 or 500/500.
I only got the 1GB Fios as it was only 69.99 so I said why not for the extra $10 a month.
Why buy a GT-AXE16000 when the GT-BE98 is almost the same price and you get more ports?
You just proved my point. 1Gb is becoming the standard entry level for fiber, with multiple tiers and 10Gb at the high end. DOCSIS 4.0 will also bring this pricing to cable customers.
Why buy a home router with whatever ports when the hardware inside can't even do Gigabit with some firmware options enabled incompatible with NAT acceleration hacks in place? Why get a 10Gbps ISP service when most clients can't reach even Gigabit or simply don't need anything faster?
This is what ISPs do right now - Gigabit for everyone and shared between more paying higher fees customers. They know very well not even 10% have the equipment, clients or need for this speed. People don't change Internet use habits overnight just because the ISP got them a "deal". The real deal is for the ISP - more money with marginal increase in traffic. There is a good deal for hardware vendors as well - new router, new switch, new phone.
I can personally attest to that... 10Gb fiber broadband was rolled out nearly 7 years ago where I'm from and all the big ISPs jumped on the bandwagon back then. Unfortunately, the take-up rate was so poor over the period (due to cost and addition gear needed to handle the higher speeds) that by end-2022, most of them dropped the service, leaving only one ISP still offering 10Gb fiber. Networking equipment that you need to handle 10Gb fiber is only just starting to gain traction but with rampant inflation becoming a worldwide problem in the supply chain, prices aren't coming down and are instead going up. Interestingly, there's now a renewed government push to upgrade the nationwide fiber broadband networks to 10Gb, will see if history repeats itself...Very few customers will pony up the $$$ for 10GB cable. Nothing out there warrants that type of bandwidth unless your running a commercial data center. Most web sites would never even support the downloads at that speed for many years.
I think Sonic offers 10G Symmetrical PON but that's just in California for now and they only provide the ONT. Yeah, there's nothing much at the moment that'll let you max out 10Gb fiber, unless you run multiple BitTorrent downloads/uploads, and 500/500 is really all you need for streaming services like Netflix, Amazon Prime etc. That might change when Wifi 7 finally gets certified (ETA by 2023). But it'll be a couple more years before devices supporting Wifi 7 hit the shelves.That sounds like our area. We are all 10GB capable with fiber to the house, near symetrical FIOS, and they still have not released multi-GIG (2.5) for one of the top 5 richest counties in the U.S. I've hear fios has multi gig in NY though.
10GB may sure make some people a lot of money some day but its utility seems pointless given the back end transport infrastructure and real world capacity for most web sites. Heck I have 1GB but may very well down grade once the promotional price runs out as I really do not need it. I got same latency on 300/300 and then 500/500.
Welcome To SNBForums
