GUI Locking Up RT-AC66U Running 380.63/380.64
So I believe I've done everything that was suggested to no avail. The symptom now is that the GUI works for about 5 minutes, after a reboot, no matter how many places I click in the GUI or how many settings I change. Following that it's unresponsive until a fresh reboot. It's almost like there is either a timer that's knocking me out after a period of time (I disabled the auto timeout) or a slow memory leak that hits after about 5 mins....
Well.. I've now made it 2.5 hours without a lockup, what was it?...... Seems to have been the Bonjour (mDNS) service on my Samsung printer that was causing the lockup. I'll report back if that turns out to be wrong. Thanks to everyone for their help!!
Glad to hear it! Did you set a domain name for the router? If you use 'local' as a domain it can cause problems with Bonjour.
The GUI locks up for me on those versions stated when I use Safari. Chrome seems to be ok. .62 works perfectly fine on Safari.
