Hello,
I just bought an Asus RT-AC68U and installed Merlin 3.0.0.4.374.42_2 FW on it. Thank you very much for this FW
My setup consists of 2 internet lines, one pppoe and the second fixed IP.
I installed the pppoe line on the wan port and the fixed ip line on lan1 port after enabling dual wan feature.
However I have a problem setting up the parameters of the connections in the WAN -internet connection tab.
I select at Wan type the wan port and configure the pppoe. Apply and then select at wan type the Ethernet line. When doing so the page does not refresh and I still see the parameters of the first line.
I tried 3 internet browsers and 4 different PC's with the same results. I also switched back to stock FW, same result, back to Merlin, same.
Can anyone please help me set up the second internet connection?
Many thks,
Claudiu
Many thks,
Claudiu
