[GUIDE] Installing aMule with Entware
Hello, are you still able to use amule on the latest merlin firmware? My amule installation stopped working, I tried to reinstall with no luck.
Do you manage to connect to servers?Through webui is very solow and connects always to the same server.
Yes. Only 4-5 servers trustworthy in these days, but reliable and working.
You may set these on the config file server.met which is maintained in turn in the config file addresses.dat which you may edit to your likings.
Also be sure to have your ports open (I recommend to change the default ones).
Regards.
Regards.
I'll try.KAd network works?
How do you connect to kad network?It requires an ip and port, and those values are empty.
Don't mean to be rude but I'm sure you can answer yourself with some googling…
We covered here the non-trivial task of deploying aMule inside Merlin firmware. It is supposed that you already know how to run and configure eMule and aMule. You have tons of guides for these themes elsewhere.
Regards.
