I used xenforo as the forum software and then did the following to install all the packages needed for xenforo and phpMyAdmin.
Telnet into the router:
Install the required packages:
Issue some more commands:
Make a database called 'forum' - change user and password to your own username and password.
More database commands:
Exit: with Ctrl-C
Copy forum files to: /opt/share/www (use winscp)
Start Website:
Once you have your website installed:
In jjfs/scripts/firewall-start - add this line:
In your router admin wan interface: port forward 192.168.1.1 from port 80 to port 81.
In your router admin administration/system: enable custom jjfs scripts.
Reboot router - that's it.
cd /
entware-setup.sh
opkg install lighttpd php5-cgi lighttpd-mod-fastcgi lighttpd-mod-scgi nano wget mysql-server php5-mod-mysql php5-mod-xml php5-mod-gd php5-mod-iconv php5-mod-ctype php5-mod-json php5-mod-mysqli php5-mod-dom php5-mod-simplexml php5-mod-dom php5-mod-simplexml php5-mod-openssl php5-mod-mbstring php5-mod-session
/opt/etc/init.d/S80lighttpd stop
mkdir -p /opt/etc/lighttpd/conf.d
wget -c -O /opt/etc/lighttpd/conf.d/99-rtorrent-fastcgi-scgi-auth.conf http://goo.gl/YK8xPQ
mysql_install_db --force
/opt/etc/init.d/S70mysqld restart
mysql -u root -p
create database forum;
grant all privileges on forum.* to user@127.0.0.1 identified by 'password' ;
( command to delete a database forum: DROP DATABASE forum;)
( command to show databases: SHOW DATABASES;)
( command to dump backup database: mysqldump --opt -h127.0.0.1 -uroot -ppassword forum > /tmp/backup.sql)
( command to restore backup database: mysql -h127.0.0.1 -uuser -ppassword forum < /tmp/backup.sql)
Exit: with Ctrl-C
Start Website:
/opt/etc/init.d/S80lighttpd restart
/usr/sbin/iptables -I INPUT -p tcp --dport 81 -j ACCEPT
