Hey all.. running an RT AC68P, upgraded firmware in feb to 380_4164.
Also changed the admin name and password back then. did backup.
All has been fine... then this morning... nothing seemed to be working and I couldn't even get to the GUI. rebooted...and now I can get to the GUI, but it won't let me login, with new or old passwords.
I'm on internet... but obviously a bit worried.... Suggested next steps?
Factory reset and upload backup?
EDIT. I actually thought I upgraded the firmware to something newer less than 6 months ago, but it's showing that version on the android app, even though I still can't login
EDIT2: Asus support actually there on the weekend. Had me factory reset. then I uploaded newest firmware, then applied backup. Seems to be back... but clearly a bit nervous.
I wonder if there is a problem changing the user login name, as that seemed to give me some challenges when I first tried it. Are you supposed to leave that at "admin", and only change the password?
