Nov 7 17:36:37 rc_service: httpd 318:notify_rc start_vpnclient1
Nov 7 17:36:37 openvpn[27863]: OpenVPN 2.3.2 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 1 2013
Nov 7 17:36:37 openvpn[27863]: Socket Buffers: R=[114688->131072] S=[114688->131072]
Nov 7 17:36:37 openvpn[27867]: UDPv4 link local: [undef]
Nov 7 17:36:37 openvpn[27867]: UDPv4 link remote: [AF_INET][COLOR="Red"]95.154.230.4:53[/COLOR]
Nov 7 17:36:37 openvpn[27867]: TLS: Initial packet from [AF_INET][COLOR="Red"]95.154.230.4:53[/COLOR], sid=848fdbb1 bb03fc4d
Nov 7 17:36:37 openvpn[27867]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Nov 7 17:36:37 openvpn[27867]: VERIFY OK: depth=1, C=UK, ST=NR, L=Attleborough, O=Hide My butt! Pro, OU=VPN, CN=vpn.hidemyass.com, emailAddress=ca@hidemyass.com
Nov 7 17:36:37 openvpn[27867]: VERIFY OK: nsCertType=SERVER
Nov 7 17:36:37 openvpn[27867]: VERIFY OK: depth=0, C=UK, ST=NR, L=Attleborough, O=Hide My butt! Pro, OU=VPN, CN=server, emailAddress=vpn@hidemyass.com
Nov 7 17:36:38 openvpn[27867]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Nov 7 17:36:38 openvpn[27867]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Nov 7 17:36:38 openvpn[27867]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Nov 7 17:36:38 openvpn[27867]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Nov 7 17:36:38 openvpn[27867]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Nov 7 17:36:38 openvpn[27867]: [server] Peer Connection Initiated with [AF_INET][COLOR="Red"]95.154.230.4:53[/COLOR]
Nov 7 17:36:41 openvpn[27867]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Nov 7 17:36:41 openvpn[27867]: PUSH: Received control message: 'PUSH_REPLY,topology subnet,route-gateway 10.200.4.1,dhcp-option DNS 208.67.222.222,dhcp-option DNS 208.67.220.220,ping 10,ping-restart 90,redirect-gateway def1,ifconfig 10.200.5.55 255.255.252.0'
Nov 7 17:36:41 openvpn[27867]: OPTIONS IMPORT: timers and/or timeouts modified
Nov 7 17:36:41 openvpn[27867]: OPTIONS IMPORT: --ifconfig/up options modified
Nov 7 17:36:41 openvpn[27867]: OPTIONS IMPORT: route options modified
Nov 7 17:36:41 openvpn[27867]: OPTIONS IMPORT: route-related options modified
Nov 7 17:36:41 openvpn[27867]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Nov 7 17:36:41 openvpn[27867]: TUN/TAP device tun11 opened
Nov 7 17:36:41 openvpn[27867]: TUN/TAP TX queue length set to 100
Nov 7 17:36:41 openvpn[27867]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Nov 7 17:36:41 openvpn[27867]: /usr/sbin/ip link set dev tun11 up mtu 1500
Nov 7 17:36:41 openvpn[27867]: /usr/sbin/ip addr add dev tun11 10.200.5.55/22 broadcast 10.200.7.255
Nov 7 17:36:41 openvpn[27867]: /usr/sbin/ip route add 95.154.230.4/32 via xxx.xxx.xxx.xxx
Nov 7 17:36:41 openvpn[27867]: /usr/sbin/ip route add 0.0.0.0/1 via 10.200.4.1
Nov 7 17:36:41 openvpn[27867]: /usr/sbin/ip route add 128.0.0.0/1 via 10.200.4.1
Nov 7 17:36:41 openvpn[27867]: Initialization Sequence Completed
