uzumakiqc
Hey guys,
I've been trying to find info on this but can't really get anything online aside from "similar" cases.
I've noticed that everytime my friend comes over with his laptop and we start playing Diablo III, my DIR-857 will eventually start to slow down and to a point where we get CRAZY lag. Ping requests sent to the router will drop packets or return with >2400ms delay only to figure out that I can't even acces the web interface of the router when said problem occurs.
Using Google Chrome I'll get a "resolving host" for about 1-5 mins loading the browser on google.com (but my pings get trough and I can load it in 5 secs with Internet explorer).
Now I'm starting to experience just slow downs in general and feeling like I'm not getting my 180$ worth of "value". Don't get me wrong when it works I get really amazing speeds and the range improved a lot!
My currrent Firmware is at: 1.02, I did the factory reset about 3 times, flashed the firmware again using every browser possible (read on d-link forums that if not done with IE could get messy)
Anyways here's the current setup info:
Dir-857 North American Model (I'm in Canada / Quebec)
ISP: Vidéotron Cable Modem
Wifi setup:
Wireless Band : 2.4GHz Band
Enable Wireless : On
Wireless Network Name : (TEST1)
802.11 Mode : Mixed N,G,B
Enable Auto Channel Scan : On
Wireless Channel : 6
Channel Width : 20/40
Visibility Status : Visible
Security: WPA-Personnal
Wireless Band : 5GHz Band
Wireless Network Name: (TEST1)
802.11 Mode : Mixed N,A
Wireless Channel : 40
Security: WPA-Personnal (same key as 2.4)
WISH is off and Traffic Shaping is off too. I notice the router runs hot but not enough to cause problems!
If anyone has any suggestions or experiences the same problems I'd like to get your feedback 'cause I'm running out of options / ideas!
Thanks in advance guys!
Wifi setup:
