Helper script question
octopus
Part of the Furniture
I'm using "pc insert" but there is a bug in new alpha build.
I can use "pc_repalce" but need a raw 1 and raw 2.
pc replace " raw 1" " raw 1 new raw raw 2" $CONFIG
like
raw 1
raw 2
someone have any suggestions?
octopus
You could directly use sed.
I'm not sure I follow exactly what it is you're doing, but the helper functions are just human-friendly wrappers for sed. So use sed directly:
sed -i "/$PATTERN/a$CONTENT" $CONFIG
You just have to be careful if $PATTERN or $CONTENT might contain any non-alphanumeric characters.
You could also just reuse the pc_insert() code from 384.9.
Who knows from description but perhaps problem could be solved with delete and append
pc_delete "dhcp-option=dnsf5" $CONFIG
pc_delete "dhcp-option=dnsf6" $CONFIG
pc_append "dhcp-script=/jffs/scripts/log-dhcp.sh" $CONFIG
pc_append "neg-ttl=3600" $CONFIG
pc_delete "no-negcache" $CONFIG
pc_delete "servers-file=/tmp/resolv.dnsmasq" $CONFIG
Thank you Colins your suggestion working fine. Thank you RMerlin.
