yorgi
Not sure unless I try your setup..That script works for openVPN I used it for the longest time until Rmerlin incorporated it in the Policy rules then I took out the script.If i do an iptables -L -v command, i get the following output for the Forward
Code:Chain FORWARD (policy DROP 0 packets, 0 bytes) pkts bytes target prot opt in out source destination 65749 4079K TCPMSS tcp -- any any anywhere anywhere tcpflags: SYN,RST/SYN TCPMSS clamp to PMTU 11M 14G ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED 0 0 DROP all -- !br0 vlan2 anywhere anywhere 0 0 DROP all -- vlan2 any anywhere anywhere state INVALID 0 0 ACCEPT all -- br0 br0 anywhere anywhere 0 0 ACCEPT all -- any any anywhere anywhere ctstate DNAT 107K 7988K ACCEPT all -- br0 any anywhere anywhere 0 0 DROP all -- !br0 ppp5 anywhere anywhere
i read this as "drop any inbound connection to vlan2 (WAN connection) or ppp5 (VPN) unless it comes from br0 (the bridge)" So does this mean that your original suggestion
Code:#!/bin/sh sleep 4 iptables -I FORWARD -i br0 -o ppp5 -j ACCEPT iptables -I FORWARD -i ppp5 -o br0 -j ACCEPT iptables -I FORWARD ! -o ppp5 -s 192.168.2.50 -j DROP iptables -I FORWARD ! -o ppp5 -s 192.168.2.60 -j DROP iptables -I FORWARD ! -o ppp5 -s 192.168.2.70 -j DROP iptables -I INPUT -i ppp5 -j REJECT iptables -t nat -A POSTROUTING -o ppp5 -j MASQUERADE
should work even though br0 is showing a LAN IP instead of a WAN IP?
br0 is your WAN port. You have a VLAN2 in the equation. I am not sure.
You need to make some tests. It took me months to figure out Policy rules with scripts.
