VPS is down, please, try again tomorrow.
PS I'm getting tired of bluevm.com hoster, this is 7th down for the last half year![]()
Okay, I'll try it again tomorrow... Thanks for the information
Take a look at Linode. Very professional support. A friend of mine has been with them for years, and I am currently in the process of migrating our dedi server at work to a Linode.
Exactly! Right.Am I right assuming this ad-blocking method will not only block content loading from ad sites (same as hosts file does) but also hide ads in the page and rearrange the page? Same as ad-block plus does in pc browsers?
Hey, I'm new to this forum, and have been searching around for answers to my question, but haven't found any.
Is there an adblock solution that will work on an asus rt-ac68u with Merlin WRT firmware? I realize the solution presented in this thread requires entware, which doesn't work on the rt-ac68u.
Thanks for your help!
This is HOW-TO for using Adblock Plus filters on router with Merlin's firmware. Better to use it with iOS/Android devices. Using with PC will slow down web surfing because of router performance limitations.
It's based on privoxy — a proxy server, which will intercept and filter all web-traffic from chosen iOS/Android device.
Requirements:
1. Asuswrt-Merlin driven RT-N16/RT-N66U/RT-AC66U router with USB-drive.
2. Working Entware environment. Please, refer to Eric's how-to for details.
Setup
1. Install necessary packages:
2. Install prepared privoxy configuration file:
3. Install script for converting AdBlock Plus rules:
4. Choose AdBlock Plus subscriptions.
Please, find "URLS=" string in privoxy-blocklist_0.2.sh and put your own subscriptions here. You may sneak subscription URLs in you favourite browser or here. The default subscriptions is a easylistgermany and easylist.
Now convert AdBlock Plus rules to privoxy format by running:
5. Choose iOS/Android/PC device where filtering needed.
Please, go to router's web interface, "LAN > DHCP Server" page, and select "Enable Manual Assignment" button.
Add your device to "Manually Assigned IP around the DHCP list". Better to do it while device is connected to router: you may select it's MAC from drop-down list and assign an IP address for it, for example "192.168.0.101". Don't forget to push "Apply" button (I did)
6. Add web traffic interception rule to iptables.
where 192.168.0.101 is an IP address from step above.
Reboot router and check web surfing on chosen device.
If you want to change AdBlock subscriptions, please remove old ones first:
then repeat step #4 only.
Nov 5 19:02:38 routeur admin: Failed to start privoxy from .
/opt/etc/init.d/S24privoxy start
Starting privoxy... failed.
ls -l /opt/var/log/privoxy
-rw-rw-rw- 1 admin root 0 Nov 5 18:47 /opt/var/log/privoxy
# ln -s libpcre.so.1.2.3 libpcre.so.0
# ls -l libpcr*
lrwxrwxrwx 1 admin root 16 Nov 5 19:34 libpcre.so.0 -> libpcre.so.1.2.3
lrwxrwxrwx 1 admin root 16 Nov 5 19:25 libpcre.so.1 -> libpcre.so.1.2.3
-rwxr-xr-x 1 admin root 272244 Oct 15 10:16 libpcre.so.1.2.3
lrwxrwxrwx 1 admin root 21 Nov 5 19:25 libpcreposix.so.0 -> libpcreposix.so.0.0.2
-rwxr-xr-x 1 admin root 6212 Oct 15 10:16 libpcreposix.so.0.0.2
Some packages was re-linked. The right way to solve it is:Issue solved with a symlink
opkg remove wget privoxy
opkg install wget privoxy
Shell script can be used on any platform. You need to find privoxy package for ARM platform.Any chance of tweaking the shell scripts to work on the newer ARM based routers (with Optware instead of Entware support)?
Welcome To SNBForums
