how to change default router setting when compile firmware from source?
consatan
Hi all,
I want to auto turn on "Enable Web Access from WAN" and "Allow only specified IP address" when I flashed meilin firmware.
If it can I also want to auto turn on DDNS, my RT-N66U already registered asus DDNS.
Hi all,
Default values are in router/shared/defaults.c.
You will need of course to do a factory default to apply new default values, otherwise whatever values are currently stored in nvram will remain in use. Default values are just that - default values used until you actually change them.
Thanks!
BTW, where is the init script path? I want add a startup bash script to the firmware.
Thanks!
There is no init scripts - the firmware isn't based on SysV init scripts, but on a custom init process (rc).
The earliest you can execute anything using the built-in script support is in init-start. See the Wiki for more info on user scripts.
