How to disconnect local pc from wifi?
OK
Now I bought a new router and got an issue with iptables in it. It is an Asus as3200 machine.
I get odd faults when trying to execute the script.
Any ideas?
+ iptables -I dropkids 1 -d 192.168.1.79 -j DROP
+ iptables -I dropkids 1 -s 192.168.1.195 -j DROP
+ iptables -I dropkids 1 -d 192.168.1.195 -j DROP
+ iptables -I FORWARD 1 -m time --timestart 19:30 --days Mon,Tue,Wed,Thu,Fri -j dropkids
iptables v1.4.14: unknown option "--days"
Try `iptables -h' or 'iptables --help' for more information.
+ iptables -I FORWARD 1 -m time --timestop 16:00 --days Mon,Tue,Wed,Thu,Fri -j dropkids
+ test xSat,Sun != x
+ iptables -I FORWARD 1 -m time --timestart 12:30 --days Sat,Sun -j dropkids
+ iptables -I FORWARD 1 -m time --timestop 09:00 --days Sat,Sun -j dropkids
admin@RT-AC3200-7C50:/jffs/scripts#
Michael
OK
Any ideas?
Michael
iptables -m time -h
so replace --days with --weekdays ?
iptables -m time -h
This is the result....
admin@RT-AC3200-7C50:/tmp/home/root# /jffs/scripts/firewall-start
+ SchoolNiteTime=19:30
+ SchoolMornTime=16:00
+ SchoolDays=Mon,Tue,Wed,Thu,Fri
+ WeekendNiteTime=12:30
+ WeekendMornTime=09:00
+ WeekendDays=Sat,Sun
+ StaticIPList=192.168.1.25 192.168.1.37 192.168.1.48 192.168.1.79 192.168.1.195
+ MaCList=24:24:0E:7E:DD:1B 40:F0:2F:83:46:BB D0:66:7B:0B:37:0B E8:4E:84:2D:CA:4D 5C:93:A2:17:86:57
+ iptables -N dropkids
iptables: Chain already exists.
+ iptables -F dropkids
+ iptables -I dropkids 1 -m mac --mac-source 24:24:0E:7E:DD:1B -j DROP
+ iptables -I dropkids 1 -m mac --mac-source 40:F0:2F:83:46:BB -j DROP
+ iptables -I dropkids 1 -m mac --mac-source D0:66:7B:0B:37:0B -j DROP
+ iptables -I dropkids 1 -m mac --mac-source E8:4E:84:2D:CA:4D -j DROP
+ iptables -I dropkids 1 -m mac --mac-source 5C:93:A2:17:86:57 -j DROP
+ iptables -I dropkids 1 -s 192.168.1.25 -j DROP
+ iptables -I dropkids 1 -d 192.168.1.25 -j DROP
+ iptables -I dropkids 1 -s 192.168.1.37 -j DROP
+ iptables -I dropkids 1 -d 192.168.1.37 -j DROP
+ iptables -I dropkids 1 -s 192.168.1.48 -j DROP
+ iptables -I dropkids 1 -d 192.168.1.48 -j DROP
+ iptables -I dropkids 1 -s 192.168.1.79 -j DROP
+ iptables -I FORWARD 1 -m time --timestart 19:30 --weekdays
iptables v1.4.14: unknown option "--weekdays"
+ Mon,Tue,Wed,Thu,Fri -j dropkids
/jffs/scripts/firewall-start: line 62: Mon,Tue,Wed,Thu,Fri: not found
+ iptables -I FORWARD 1 -m time --timestop 16:00 --weekdays
/jffs/scripts/firewall-start: line 64: Mon,Tue,Wed,Thu,Fri: not found
+ iptables -I FORWARD 1 -m time --timestart 12:30 --weekdays
+ Sat,Sun -j dropkids
/jffs/scripts/firewall-start: line 72: Sat,Sun: not found
+ iptables -I FORWARD 1 -m time --timestop 09:00 --weekdays
So does the command
iptables -m time -h
on your router show the available syntax ?
I have RT-AC56
ASUSWRT-Merlin RT-AC56U_3.0.0.4 Sat May 30 21:47:01 UTC 2015
admin@RT-AC56U:/tmp/home/root# iptables -m time -h
iptables v1.4.14
Usage: iptables -[ACD] chain rule-specification [options]
       iptables -I chain [rulenum] rule-specification [options]
       iptables -R chain rulenum rule-specification [options]
       iptables -D chain rulenum [options]
       iptables -[LS] [chain [rulenum]] [options]
       iptables -[FZ] [chain] [options]
       iptables -[NX] chain
       iptables -E old-chain-name new-chain-name
       iptables -P chain target [options]
       iptables -h (print this help information)
Commands:
Either long or short options are allowed.
  --append  -A chain            Append to chain
  --check   -C chain            Check for the existence of a rule
  --delete  -D chain            Delete matching rule from chain
  --delete  -D chain rulenum
                                Delete rule rulenum (1 = first) from chain
  --insert  -I chain [rulenum]
                                Insert in chain as rulenum (default 1=first)
  --replace -R chain rulenum
                                Replace rule rulenum (1 = first) in chain
  --list    -L [chain [rulenum]]
                                List the rules in a chain or all chains
  --list-rules -S [chain [rulenum]]
                                Print the rules in a chain or all chains
  --flush   -F [chain]          Delete all rules in  chain or all chains
  --zero    -Z [chain [rulenum]]
                                Zero counters in chain or all chains
  --new     -N chain            Create a new user-defined chain
  --delete-chain
            -X [chain]          Delete a user-defined chain
  --policy  -P chain target
                                Change policy on chain to target
  --rename-chain
            -E old-chain new-chain
                                Change chain name, (moving any references)
Options:
    --ipv4      -4              Nothing (line is ignored by ip6tables-restore)
    --ipv6      -6              Error (line is ignored by iptables-restore)
[!] --proto     -p proto        protocol: by number or name, eg. `tcp'
[!] --source    -s address[/mask][...]
                                source specification
[!] --destination -d address[/mask][...]
                                destination specification
[!] --in-interface -i input name[+]
                                network interface name ([+] for wildcard)
--jump -j target
                                target for rule (may load target extension)
  --goto      -g chain
                              jump to chain with no return
  --match       -m match
                                extended match (may load extension)
  --numeric     -n              numeric output of addresses and ports
[!] --out-interface -o output name[+]
  --table       -t table        table to manipulate (default: `filter')
  --verbose     -v              verbose mode
  --line-numbers                print line numbers when listing
  --exact       -x              expand numbers (display exact values)
[!] --fragment  -f              match second or further fragments only
  --modprobe=<command>          try to insert modules using this command
  --set-counters PKTS BYTES     set the counter during insert/append
[!] --version   -V              print package version.
time match options:
    --datestart time     Start and stop time, to be given in ISO 8601
    --datestop time      (YYYY[-MM[-DD[Thh[:mm[:ss]]]]])
    --timestart time     Start and stop daytime (hh:mm[:ss])
    --timestop time      (between 00:00:00 and 23:59:59)
[!] --monthdays value    List of days on which to match, separated by comma
                         (Possible days: 1 to 31; defaults to all)
[!] --weekdays value     List of weekdays on which to match, sep. by comma
                         (Possible days: Mon,Tue,Wed,Thu,Fri,Sat,Sun or 1 to 7
                         Defaults to all weekdays.)
    --kerneltz           Work with the kernel timezone instead of UTC
or did you add a LF after the --weekday clause... :eek:
PEBKAC!
I have an RT-AC3200 using firmware 380.63_2 when I look at the iptables man page, it looks like the days option is missing. Im trying to use the script in post #12 above.
What can I use in place of the --days option?
Hi Colin, can you think of any reason why this script doesn't re-enable? It drops fine with the SchoolNiteTime and WeekendNiteTime, but then it doesn't re-enable with the SchoolMornTime or the WeekendMornTime.
I will reply in your other thread.
