Are you using DNSCrypt?Can anyone tell me which of the blacklist IPs might stop my DNS working? I love this script but the wife isn't happy when things just stop working for no reason!
https://pastebin.com/hmc27y1M
I don't use DNSCrypt and I am not having any problems. So I suspect that is where the problem lies.Yeah to OpenDNS, but I thought I had whitelisted their anycast IP
That's my gut instinct too, but I wouldn't know where to start. Well, my attempt was whitelisting the IP that DNSCRYPT was proxying to, and that obviously isn't right! HahaI don't use DNSCrypt and I am not having any problems. So I suspect that is where the problem lies.
Same, not instant, can be 10-15 minutes, or several hours, with the latest being overnight. I have TrendMicro enabled, perhaps I will disable it and see how it goesI tried whitelisting opendns ips while using dnscrypt. I also didn't find their ips in the blocklist.
I have several variables in play and am slowly working my way through the permutations to see which may be the culprit. It doesn't happen instantly, only after a couple of hours. I didn't remember the commands that were recommended to run when it happened last night (and I had not printed them out... It could be a dnscrypt/trendmicro rather than a dnscrypt/ipsetblock.
Hey, Xen!Here is a small utility script to download IPSET_Block.sh and HackerPorts.sh, format for Linux and chmod 755 on the files. Call whatever you want (e.g. get-ipblock-scripts.sh), just remember to chmod to be executable. e.g. chmod 755 get-ipblock-scripts.sh.
Code:#!/bin/sh #Get IPSET_Block.sh script from pastebin, convert to linux format and set permissions to 755 wget https://pastebin.com/raw/zQ3KEe8P -O /jffs/scripts/IPSET_Block.sh; dos2unix /jffs/scripts/IPSET_Block.sh chmod 755 /jffs/scripts/IPSET_Block.sh #Get HackerPorts.sh script from pastebin, convert to linux format and set permissions to 755 wget https://pastebin.com/raw/LRHJih8Z -O /jffs/scripts/HackerPorts.sh; dos2unix /jffs/scripts/HackerPorts.sh chmod 755 /jffs/scripts/HackerPorts.sh
Yes, if he changes the pastebin link, then the http in the script needs to change to reflect the new url. I wondered about that. The init is the key to getting it working correctly.Hey, Xen!
That script d/l version 2.05 of HackerPorts. I had to revert back to v. 2.03 to work with IPSET.
Martineau must be setting up a new version, so we need to be careful when using the wget I think!
I think I found my problem!
When you and I were discussing the firewall-start and services-start. I had changed my firewall-start and edited out the init part of the script, so it wasn't re-running the init. After running it manually. It seems to be working again!
My experience has led to using these scripts and turning ai-protection off. It uses far to much ram to be doing more than what these add on scripts do. I think it is a little Asus bloat actually.I tried whitelisting opendns ips while using dnscrypt. I also didn't find their ips in the blocklist.
Yes!Yes, if he changes the pastebin link, then the http in the script needs to change to reflect the new url. I wondered about that. The init is the key to getting it working correctly.
This is my understanding and I could be wrong. So caveat warning applies.Yes!
I think you are right.
I have another question.
Is there a safe way to stop logging the "Block In"'s from the syslog without messing up the function of the IPSET script?
I know there is some explanation within the script, but that seems to be over my head. Could you break that down in simple idiot English?
'IPSET_Block.sh v4.xx' optionally uses an IPSET as a crude database for logging the hack attempts as well as, or in place of, Syslog messages)
@Martineau
I want to make sure AB-Solution does not block the domains used for your script's lists.
I'd like to include the url list file this script uses to whitelist them in AB-Solution.
Is there a permanent file stored on the users device with the url's?
If so, please let me know the standard path/filename to it.
I think you are referring to the nolog option. But if this option is used, no 'Block =' messages will be generated in the system log file, which the report reads from. So, no messages in system log means no data in the report.
I see a comment in HackerPorts.sh
This leads me to believe that a version 4.xx of IPSET_Block.sh is in the works that will use the IPSET as a database to report from. Perhaps logging to the System Log will then no longer be necessary. I am sure @Martineau will be back once the weekend roles around and correct meCode:'IPSET_Block.sh v4.xx' optionally uses an IPSET as a crude database for logging the hack attempts as well as, or in place of, Syslog messages)
Yes Please! I would like to test v4.01. And thank you for clarifying the HackerPorts v2.03 functionality. I saw the comment but did not realize the feature was available. I did not see a link to the 4.01 version in the forum unless I missed it. The link on the wiki goes to version. 3.04.@Xentrk I see from your post yesterday
https://www.snbforums.com/threads/i...-for-ipset-v6-and-v4.37976/page-9#post-325388 that you appear to still be using this script?
If you want to have a copy of IPSET_Block v4.01 then let me know.
NOTE: HackerPorts v2.03 already has support for reporting the stats from the IPSET (rather than the syslog messages).
./IPSET_Block.sh save
./IPSET_Block.sh backup
./IPSET_Block.sh init reset ipset
./IPSET_Block.sh restore
./IPSET_Block.sh status
v4.01 © 2016-2017 Martineau, Dynamic IPSET Blocking.....
Name: Blacklist Name: Whitelist
Type: hash:ip Type: hash:net
Revision: 0 Revision: 0
Header: family inet hashsize 4096 maxelem 65536 timeout 604800 Header: family inet hashsize 1024 maxelem 65536
Size in memory: 174168 Size in memory: 8500
References: 3 References: 2
Members: Members:
(Total=11044) (Total=0)
Summary Blacklist: 157+0 Successful blocks! ( 11047 IPs currently banned - 3 expired since: May 18 20:00 ), Entries auto-expire after 168:00:00 hrs
v2.04 © 2016-2017 Martineau, Hacker Port attacks Report.....
Retrieving IPSET BlacklistTRK data for 'eth0' violations, please wait.....
4177 members retrieved from IPSET (BlacklistTRK)
18 May 20:15:49: # Unique Ports attacked via 'eth0': 177 (out of 4177 attempts) tracked via IPSET
Top 3 Ports attacked:
2488 http://www.speedguide.net/port.php?port=23 e.g. https://www.speedguide.net/ip/1.180.214.77
293 http://www.speedguide.net/port.php?port=22 e.g. https://www.speedguide.net/ip/101.69.196.100
187 http://www.speedguide.net/port.php?port=81 e.g. https://www.speedguide.net/ip/103.239.74.110
Top 3 attackers:
1 https://www.speedguide.net/ip/1.180.214.77
1 https://www.speedguide.net/ip/101.69.196.100
1 https://www.speedguide.net/ip/103.239.74.110
Last 3 most recent attackers:
https://www.speedguide.net/ip/109.236.91.106
https://www.speedguide.net/ip/94.142.139.243
https://www.speedguide.net/ip/122.114.173.66
./IPSET_Block.sh status noipset
@Martineau I'm interested in your HackerPorts. PM me pls if you may..
Welcome To SNBForums
