Hiya Guys question please....
I've got the RT-AX86U Pro and with CakeQos setup and working very nicely indeed .
To my understanding obviously CakeQos disables "Hardware Acceleration" as it does not use hardware acceleration.
I also understand that Asus "AdaptiveQos uses Hardware Acceleration when enabled .
I have read that for the RT-AX86U Pro enabling hardware acceleration is under
Under LAN then Switch Control then it gives you
NAT Acceleration & Enable Jumbo Frame
I've seen that in some screenshots online ...
So do I take it these particular settings/options will only appear if I switch off CakeQos ..
Many thanks.
Many thanks.
