I fail to see how Apple is "hyper-proprietary" with regards to Wifi access points - they comply with Standards - they do have their bonjour/mDNS stuff (and they don't play well with uPNP), but for AP/Client connectivity, they're no different than any other client...
From trying to help folks with their Apple WiFi products, esp. for interoperability, I learned that I'll take a pass on Apple WiFi.
My opinion and nothing more.
I have a 3 story house that is fully wired with Cat5e. I'd like to put wireless on all 3 levels of the house and would like to know the best way to go about this.
Am I correct in thinking that I can put an AP on each floor with the same SSID and password and I should be good?
Suggestions? I have a NAS and printer that my plug into whatever router or AP I get as well. I'd also like one particularly powerful wifi point on the middle floor so that I can get wifi in the backyard as well.
At least for the older 11n dual band express, probably about the best "wall plug" format router/AP you can buy still (especially when you factor in how cheap you can get them). Though kind of limited with only a single fast ethernet port.
totally cool with that
Apple hasn't done themselves any favors recently with iOS 8 and later - looks like however, 8.3 might be a winner - couple of days into it, and it seems to have fixed most of the problems that people have had... same goes with 10.10.3 for the desktop OS...
But as a couple of people have mentioned - Apple has a certain way of doing things - but it's important to know and understand how their gear works, because if you're freelancing or consulting (or a network manager), those devices are out there, and there are a lot of them.
Client issues aside, I do find Airports to be some of the most robust and stable AP/routers out there in the SOHO space, with the least number of issues to be solved.. they may not be the absolute fastest or feature rich, but most of my clients prioritize the fact that the network just works...
Well, yes, sadly there is that.Too bad they're only single band though - either 5Ghz or 2.4 - the newer one is simultaneous dual-band, which is pretty good, but I did like the first gen 802.11n Express for travel...
I've been kind of tempted to take a first gen, along with a travel router and USB LTE modem to bodge it up in my car.
That way I can connect to a vehicle 5GHz WLAN for airplay and still get out to the internet at the same time. Plus, longer range as I higher gain on most USB LTE modems from what I have seen (and some of course support external antennas).
Just not sure it is worth the on going cost (because, LTE modem = having to pay extra monthly fee, even if it is attached to my current wireless account, sigh). I do think it would be a fun project though.
I suppose that's one way...
Alternately - I have an ATT UnitePro, which is a dual-band LTE MiFi type of device, and I just use Bluetooth for my audio (my car as a decent built-in BT HFK/Audio integration)... I've seen the UnitePro's on eBay and Amazon for under $100 USD, and they are excellent performers as 2-stream, concurrent dual-band (and it can also support guest network as well).
Add a pre-paid ATT SIM, and go month to month as needed...
Welcome To SNBForums
