I'm having connection issues using 380.66.6 - Authentication failed.
Jul 3 18:07:43 openvpn[28264]: AUTH: Received control message: AUTH_FAILED
Jul 3 18:07:43 openvpn[28264]: vpnrouting.sh tun13 1500 1622 10.19.10.6 10.19.10.5 init
Jul 3 18:07:43 openvpn-routing: Configuring policy rules for client 3
Jul 3 18:07:43 openvpn-routing: Removing rule 10501 from routing policy
Jul 3 18:07:43 openvpn-routing: Tunnel down - VPN client access blocked
Jul 3 18:07:43 openvpn-routing: Adding route for 192.168.1.8 to 0.0.0.0 through VPN client 3
Jul 3 18:07:43 openvpn-routing: Completed routing policy configuration for client 3
Jul 3 18:07:43 openvpn[28264]: /usr/sbin/ip route del 10.19.10.1/32
Jul 3 18:07:43 openvpn[28264]: ERROR: Linux route delete command failed: external program exited with error status: 2
Jul 3 18:07:43 openvpn[28264]: /usr/sbin/ip route del 37.221.166.146/32
Jul 3 18:07:43 openvpn[28264]: /usr/sbin/ip route del 0.0.0.0/1
Jul 3 18:07:43 openvpn[28264]: /usr/sbin/ip route del 128.0.0.0/1
Jul 3 18:07:43 openvpn[28264]: Closing TUN/TAP interface
Nothing changed since upgrading, so I'm going back to 380.66.4
Hi, you cannot run 2 simultaneous clients from the same company at the same time. This can give you router conflict and you can leak DNS. Enable each client as you need it. or get another service provider for the other client.I've the excact same problem, but only on client-1.
I'm using 2 clients with the excact same setup except the Server Address.
Client-2 is running with no problem day after day, client-1 is closing the tunnel almost every day![]()
If that is the case then default the VPN client that you are having problems with and enter the values again and see what happens. PIA servers are not all alike. some drop and have connection problems when re establishing a connection. Example the montreal server is rock solid and the toronto server is flaky sometimes.Oops,
I did this all the time![]()
Just to be sure when you default your client 1 put the info of the client 2 instead and put the client 1 on client 2 so you can eliminate the dropping of server being the router or just the server end.
-Popup: "Warning (17) while importing file -
you will need to manually provide the CA, CRL content, on the keys/certificates page."
- .ovpn file is no longer listed on page.
Did you do what it said in that popup?
Should be changed so as to show user it's got settings loaded etc. I'm sure stock FW still lists/updates details. Would reduce user headache.That's normal. The file is only used to import settings, afterward it's discarded.
Can you post a screen shot of your OpenVPN Client page? I'll look it over to see if I can spot the issue. Who is your provider?Yeah, however still wouldn't work. So uploaded .ovpn file first & then all other settings, which isn't really explicitly clear in any instructions I've read (to be fair, it is a little confusing, as you need to upload ovpn first, then go through basic settings, THEN change service state. Not intuitive for first time users). SHA256/AES-256-CBC fails to authenticate so still trying to troubleshoot this, but least have SHA1/AES-128-CBC working for now.
Thanks![]()
SHA256/AES-256-CBC fails to authenticate so still trying to troubleshoot this.
If you don't want the service to start when you reboot the router take out the option start at WAN.Thanks for the help.
Oddly enough, this is now working despite no changes by me. EDIT: nope, spoke to soon. Now neither work.
On side note: Service State refuses to stay off if router gets rebooted.
And every 2nd time item gets changed, it's doing "Please wait,193% Applying Settings" ie 200% lol
can you upload your .ovpn file here so I can see it. I can tell you how to manually configure the router if I see the file.Ok so haven't been able to get VPN to work, stock firmware & now even Merlin.
ASUS RT-AC3200.
Merlin FW: 380.67.
Went through all settings & made sure they were where I wanted them. Nothing fancy. So...
VPN->OpenVPN Client Settings:
Clicked "Default".
Change all "Basic settings" & apply.
Then;
Import .ovpn file;
-select file.
-upload.
-2 seconds later page reloads/refreshes & as such;
-settings change, including Username/Password Authentication, they change to router login details.
So no matter what I do, every time I upload .ovpn file the page reloads itself. I didn't have this problem on stock firmware. And system logs have nothing that I can see help. So if I can't get this to work, I'll have to roll back to stock firmware as this is only reason I've tried Merlin :/.
EDIT: have tried using FF browser & now IE. Same problem with both.
maybe you downloaded the wrong certificates for 256, default the VPN client and start it again.
There is no way that PIA won't work on Merlin. At one point I noticed PIA was making some changes to their servers and connections would time out or error on connection. Its now stable and I don't see that problem anymore.
Double check your options and I would suggest default the VPN then reboot the router and put the info in there again and see what happens. IF you are still getting these problems then you should consider factory reset the router.
Hican you upload your .ovpn file here so I can see it. I can tell you how to manually configure the router if I see the file.
i don't think the Asus DSL 68U modem/router is supported by MerlinHi
I have just joined the forum, I got an Asus DSL 68U yesterday, I want to set up a VPN client and I am with PIA for VPN.
I have read up on getting the Merlin firmware into the router but I am having problems, it's telling me that the firmware is invalid, I tried rebooting, I tried using the original Asus firmware and the latest Asus firmware, I just cannot get the firmware accepted by the router.
I must be doing something wrong, I am going to read this forum and see if this thread or another has the information, sorry to post first but there are a lot of posts and if you or someone else has the info I need it will help me faster if I get a response.
All I want to do is setup the router so everything except the X Box One S goes through a VPN, I hope that is possible but first I need to be able to get the Merlin firmware installed.
I also do not know what PIA certificate and CA to install, I wonder if someone has links, I want to use Open VPN.
Thanks in advance.
Oh pity, yeah just read that link.i don't think the Asus DSL 68U modem/router is supported by Merlin
see here >> https://www.snbforums.com/threads/asus-dsl-ac68u-merlin-firmware.18261/
Welcome To SNBForums
