I can't connect to my ISP with firmware 3.0.0.4_376.48_1
Where can I see this setting?
attachment.php
I wish I could help you out but I know jack diddly outside of cable modem connections.
To VVS:
You can't see that setting (DHCP query frequency) when using L2TP. It's only used when WAN connection type is set to "Automatic IP". So don't look for it with your required L2TP connection because you won't find it.
To VVS:
This option will change to L2TP, if I change it in the settings for Automatic IP?
