stambeccuccio
Hi Merlin,
I'd like to point a small thing, but that have a negative impact on the aesthetics and image.
The "Powered by Asuswrt-Merlin", placed on the router's home page, has two icons (the router and the Merlin's hat) that are too large, they are not centered and exit out from underlying containment band, with a visual effect and aesthetic really bad, it sounds like a "fake", "sticky", "approximate thing".
So I suggest:
- zoom out the two icons, or
- move "icons and the written" slightly lower, perfectly centered in the background bar.
Sorry if I point out this "frivolity", perhaps for you is more important the substance than the aesthetics, but I can assure you that this logo does a negative effect and gives a feeling of fake, a poor accuracy, a less attention to detail and it does not valorizes the great work you do every day.
In short, it is also a question of image.
Sorry again, and congratulations for the great and good work you do every day.
