I am having a heck of a time figuring out what interface is what on the AC87. I want to monitor LAN, WAN, and 2.4 and 5gHz wireless bandwidth with SNMP.
For now I am using PeakHour on OS X, just because it is easy to set-up. I don't know if this is what I will ultimately use, it is just for plinking around and helping me understand what is what.
There results I get with bandwidth-monitoring tools simply do not make sense. In particular, wireless traffic doesn't make sense to me. I do a speed test from a wireless device to the Internet, say, on 2.4 gHz, then disconnect and reconnect on 5gHz and repeat. I see traffic on BOTH interfaces, in opposite directions, so it just doesn't make sense. Obviously, I am not looking at what I think I am looking at!
PeakHour itself suggests that vlan2 is the WAN interface, and is shown with my WAN IP address.
I am assuming, then (just naming convention...) that vlan1 is LAN? There is no IP address listed in PeakHour for eth0, though. It does list a MAC address, which is the same on eth0, vlan1, and eth1.
I conclude from this that eth0 and eth1 are 2.4 and 5gHz wireless interfaces, but I do not know which one is which. And this is where it gets crazy and infuriating. I do a speed test from a device on one, and I see traffic on both. And the values I get just don't make sense at all. (I guess PeakHour is probably just a crappy app...)
I thought it would sort out easily - that I would do a speed test and see a huge bump on two interfaces. Hahahahaha! Er, no.
There is also bra, which has some 169. address on it (what is this?), lo (127.0.0.1, I understand this, loopback address) and aux0, which has the same MAC address as eth0, vlan1, vlan1 but PeakHour shows a red dot on this one (others are green).
Can somebody clarify what is what?
(Sorry, I know this is a duplicate, because I read a post with this info. Problem is, I can't find it again! Hopefully, a clear title on this post will help other find it in the future...)
