Install Merlin over the top of DD-WRT
t0p8uzz
Evening all,
I want to go back to Merlin, is it possible to install on to an N66U currently running DD-WRT via the normal Admin > FW Upgrade method, or do I need to revert back to Asus stock FW, and then do a Merlin upgrade?
Thanks in advance!
Jim
Evening all,
Thanks in advance!
Jim
There is no difference installing Asus firmware or Merlin build firmware. Download the file unzip it and install. Make sure you do a factory reset after the install.
Evening all,
Thanks in advance!
Jim
Change the .trx ending on it to .bin and install it through the upgrade tab on dd-wrt.
Be careful. DD-WRT encrypts the router password and you can get locked out in the transition. The following is from a DD-WRT to Tomato wiki, but I believe it can also apply to Merlin's fw.
If you're upgrading from the DD-WRT firmware, telnet into the router *before* upgrading and type "nvram get http_passwd". The result will be your password in Tomato. This is necessary because of a change in DD-WRT's way of using the standard http_passwd variable.
I've done the steps I've listed probably 50 times. Never had trouble. Of course reset the dd-wrt router before flashing back to asus/Merlin.
Renamed the .trx to .bin, flashed from DD-WRT admin, it flashed ok, did a reset and all was good. Didn't need to use the encrypted DD-WRT password but obtained it prior anyway.
Finally my 5Ghz network is back and I seem to be squeezing an extra 1.5mbps on speedtests. I was sure something wasn't right with DD-WRT
Thanks for the help guys!
That's the problem with DD-wrt. it's packed with features but stability is not one off them.
Merlin misses some features but it's stable and at the end of the day.. that's what counts for me.
