Intel SS4200-E Lives Again
Well I found this little Jewel today... and I'm pretty happy I did. I have 2 current fujitsu Home Scaleos... or the ss4200. Currently running 4 2tb drives in raid 5. Its a backup of all my data, movies, pictures, music, games, but its passed its limit. I have a couple DNS 323s that run alt-F with larger drives that serve me well other than the stupidly slow transfer rates.
So I am looking for the best way to get the most out of my little system. I was intially looking for something along the lines of alt-f to let me load larger drives as that's all I really need. I'm ok with the read speed and write speed as I never need it right now and the DNS 323s are always up and running albeit slow.
So my question is what seems to be the largest drives to work in these systems? I know 2tb work, and I am curious if anyone actually tested the 4tb. I did try to check the xigma post but I have yet to actually find it again. Thanks Schof for the location update as I was concerned it was lost info.
Obviously I could buy some newer fancier piece of equipment, but this thing has been running every day for something like 9 years. ( I did have data loss with orange lights once due to being at my aunts with faulty power) But the drives are OOOOLLLDDD western digitals that I had planned to replace with some 3tb Seagates intially, and they just haven't died. One drive is definitely failing but still manages to limp along.
So now I would like to at least put some 4 tb drives in, or bigger if an option. Also wanted to keep this thing alive.
Power supply died after 10 years of 24x7 use :(
Fortunately I had purchased a backup so swapped DOM and HDs and was up and running quickly :)
Got me thinking about upgrading my system again. I've read in this thread that a CPU upgrade is worth it. Anyone know what motherboard the enclosure came with and which CPUs are compatible / suitable replacements for the Intel Celeron CPU 420 @ 1.60GHz)?
Incidentally, they have changed the XigmaNAS forum at the end of '20 and didn't transfer the old contents. Fortunately the old posts are still available here but they will eventually be taken offline which is unfortunate because they contain alot of great content regarding the Intel SS4200-E. Anyone know how to get the whole thing archived in https://archive.org?
Good think it's pretty much just a standard power supply so you can use a regular atx in a pinch to get back up and running. :) Great that you had some spare parts. :)
So the best upgrade that would not stress the original design while providing a performance boost is the celeron 450. I actually have one of these and plan on using it in my frankenstein build, but haven't gotten to work on that yet:
There are some dual core ones that you can use, but the tdp doubles and seems to have been a reason for early power supply failures in my research.
I would simply print to pdf all the relevant threads. If you want to do that and get me a copy, we'll figure out a way to put them online. :) I'm not sure how archive.org would do it and if it would be timely enough.
Welcome! Very cool about the DNS323 and alt-f--sounds like these are a bit of a gem as well if you need a very basic nas.
I finally have 4x 4TB drives, my cf card, my dell adapter, and my power supply for my frankenbuild/restoration. But it will probably be after May before I will be able to mess with it due to life. I believe I did run across a stock installation of 16TB or at least a 4TB drive at some point, but I can't remember where now. (Maybe I mentioned it in this thread?) I'm pretty confident that 4TB drives will work, but it has been a while since I have researched the topic, but I know I wouldn't have made a goal of acquiring all these drives if I didn't think it would work. :o
If you are running something like openmediavault or freenas, there is no real limit as I believe the sata controller maybe had a 16TB limit in my research. So in theory you could make a 64TB nas out of the hardware with the right nas os.
What is really neat about the ss4200-e is that it will work with drives that have bad sectors, failing smart, etc. When I put such drives in one of synologys, it refused to even look at them. And with raid 5 or raid1/1+0 that it runs, data loss isn't very likely so using marginal drives is possible.
However, this being said, raid in general cannot determine if 'bit rot' has occurred so it is possible to have data corruption and not even know it. The only way to really confirm or check this is to have other copies of the data and compare all the copies. I try to do this regularly with my important data.
If you're running the unit stock, I'm fairly certain 4TB drives will work, and if you're using something else, I'm certain it will work. Hopefully life will let me get back to this neat machine as my other two are working great. :)
Yes I read all your handy work. It was nice seeing this system honored as such. The DNS 323 I think originally only worked with 1tb drives. It's old, it's slow. I had a failure last week, woke up one morning to find my nas was not online. Assumed it had a power hiccup. Logged i to nas, after a reboot to find it registered no drives!!! Removed drive, put in pc, showed a file system but couldn't access it. I have everything redundantly backed up, so eh.. I wiped the drive put it back in still no disk. Uh oh. So DNS must have gotten corrupted. Flash the firmware to factory.. still nada. Pulled my backup nas out hooked it up out drives in.. no disks. Now I panick lol. I put the drives that sit in that enclosure back in 6tb seagates fairly new, no disks. Well crap.
So I unhook them take them to the workstation hook it up.. drives are back. So I flashed both DNS for nothing, all 4 drives were fine. Power supply died just enough to not work. 4 pin new one off amazon on its way. Haha.
Now back to this ss4200. I don't mind that they are slow. They have been stable, roughly 3 times faster read than the dns. My first 4200 I bought off eBay as a backup for my dns in I think 2011 or 2012. Came with 4 2tb western digital drives that have been suspect since I got the device. Still work to this day though drive 4 will occasionally have to be rebuilt.
I'm not opposed to the dual core processor or the upgrade in ram. I have been searching tirelessly for alternate OS to get me larger drives. I'd like to use it with a minimum of 4 6 tb drives. Of course the other day 8tb were the best deal but anything larger than 4 will do the job for now. I'm still using the emc software, and... It's sometimes finicky. In short if I can throw 4tb drives in one I will do that now.. but would like to eventually drop bigger drives in the other one. So any guides on operating systems for this thing would be greatly appreciated. Admittedly it's slow, but it isn't bad looking and seems rather reliable. A friend got the seagate black armor and it's a monster in power by comparison. But it only came with 4 3 tb drives and was stupidly expensive. It's worlds faster, but to watch a movie from my iso files is no issue and I picked up my last 4200 for 45 dollars shipped. I have pc servers as well but the power on those xeons with high end video cards is stupid.
Thanks for your time and dedication. Even if I was the only one to find it a joy I think you've done a good job documenting and trying.
I've been using XigmaNAS running 4 x 8Tb (ST8000AS0002-1NA17Z) drives in raid1 configuration for quite a while now and everything is peachy.
Have you installed a video card or do you want to do a headless install?
Do you have an extra DOM or have an image of the old one you can re-flash if the install fails and you want to revert back to the original?
I have 2 stock machines. So I will have a way to get back the old system if it's viable.
As to extra parts, or video card installed I do not. I would have some video cards floating around. Though I'm not sure which ones work.
I'm thinking of trying my 3tb drives this evening. But in all honesty I need 6tb drives to house my mound of movies, photos, games and such.
But raid 5 on 4 3tb drives would cover most of my movies, other than blu ray.
I'm also curious if I pulled my 2 tb drives if I could build that machine with 3tb drives with the option just to change out drives and keep my raid build.
For me the easiest installation method was to install a riser card in the SS4200 so I could attach an old video card and do the installation right on the NAS itself. Once I had that in place I downloaded the latest embedded XigmaNAS build and copied it to a USB stick that I had Hiren's boot CD on. Then I plugged the USB stick into the NAS and booted from it. Once it Windows I cleaned the DOM using diskpart and flashed it sing physwrite. I rebooted into XigmaNAS, setup the network interface, etc and was then set to configure it further from any computer on the network.
I had previously flashed the DOM using a windows computer before installing it in the NAS but it uses an old interface which my newer computers don't have so ended up using the approach described above.
Here are some links you might find useful:
The XigmaNAS forums are the best source of help. The admins there, particularly raulfg3, are excellent.
I submitted the old XigmaNAS forums to the internet archive so if you have an old URL you can access them as follows:
URLs from before Dec 12th, '20:
https://www.xigmanas.com/forums/index.php > https://web.archive.org/web/20210312223823/https://www.xigmanas.com/oldforums/index.php
URLs from after Dec 12th, '20:
https://www.xigmanas.com/oldforums/index.php > https://web.archive.org/web/20210312223823/https://www.xigmanas.com/oldforums/index.php
This is greatly appreciated. Having tried to find that info this is amazing. Hopefully I can get this figured out and will find myself super happy haha. I see a ram upgrade in the near future. Looks like I have a lot of digging to do to find the path to get my system to the point I want.
One other important point that I don't know if you are aware of and don't recall whether it's specified elsewhere in this thread... the bios hides the IDE Port from the OS, but in Recovery Mode it is shown. So when you want to install, start or simply access anything on the DOM you have to put your NAS in recovery mode. You do that by holding down the small button on the back of the NAS. Since I always want to use the DOM I put a screw in that hole that keeps the button permanently pushed in. You can try a pin or anything else to jam it but be careful not to exert too much pressure because the piece holding the pin can break.
Attaching some PDFs that might come in handy. User guide is too large to attach so here is the link to it.
Thank you so much for sharing and the nice words. On the stock emc software, I'm pretty certain 4TB is the limit but I still haven't tested it yet. And apparently with alternate OSes I have run into people that have got it to hit gigabit speeds, so it has potential for sure.
I have pulled a set of drives out and used another set and then put the other ones back in without issue. The raid configuration and everything seems to be on the drives so you should be able to install your 3tb and still have your 2tb set as a backup. You can also read that 2tb set natively by connecting them to a computer and booting a linux live cd. I have the exact one someone tried in my offline notes somewhere, but I believe it was a ubuntu live cd and the whole volume showed up.
Thank you so much for all this! Now I'm even thinking about trying a XigmaNAS build as well. :) I know the image might be big and we'd have to find a way to transfer it, but would you mind making a clonezilla image of your DOM and sharing it? Then all one has to do is write the image to the DOM and then boot the SS4200-E on it to have XigmaNAS. :)
I guess now I have 2x experiments to try--the 4x 4TB stock build, and a 4x 16TB XigmaNAS build. :D And I still haven't finished confirming that the 6x 16TB drives will work in my Netgear NAS for 96TB of storage. o_O So much NAS fun, so little time...and the SS4200-E Lives on! :D
You can get the latest XigmaNAS embedded version directly from the SourceForge site and then just follow the instructions above. Once you get it up and running please let us know how you fare w/ the 16Tb drives. An upgrade may be in order ;)
Thank you! So basically all you have to do is write the embedded image to a boot drive and then just boot it? Then set up a few odds and ends and that's it?
Most definitely! I actually just got a 4th ss4200-e from the same person that I got my original one. :) It will need some restoration, but I have the opportunity to set up XigmaNAS on it from the get-go. :)
Now, I just have to find time for all this NAS fun. :D And then 4x ss4200-e's will be living on. :)
Hey folks, I hope some of you are still watching this thread. I just tried installing Open Media Vault (on Debian Linux) on my SS-4200, upgraded to 2GB RAM. Discovered that it won't boot from USB if there are any partitions, even unpopulated, on any IDE or SATA disks connected to the motherboard. That is, it starts the boot, the access lights blink on the USB stick a few times, then it just stops, I get a flashing cursor at the top of the screen, and that's it. Thoughts?
I would try another flash drive--one that's smaller than 2GB as that was an issue back in the day of the SS-4200. Hope it works! Also, where did you get your version of Open Media Vault? I want to try it too at some point.
