It's technically headless but it's easy enough to hook up a cheap video card, as we've discussed earlier in this thread.That is the way a lot of people have installed to it since it's headless anyways. But the problem is that if it doesn't boot you don't know what's wrong.
I aware of that, but it's also a risk as the cooling doesn't function the way it should and the case has to stay open in an odd way. I'd personally install on some other media and move it over.It's technically headless but it's easy enough to hook up a cheap video card, as we've discussed earlier in this thread.
Using a flex PCI-e riser, you can place drives 3&4 in the correct position over the CPU, which gives enough ventilation during the installation.I aware of that, but it's also a risk as the cooling doesn't function the way it should and the case has to stay open in an odd way. I'd personally install on some other media and move it over.
root@omv-ss4200:/zfs_data# zpool status zfs_data
pool: zfs_data
state: ONLINE
config:
NAME STATE READ WRITE CKSUM
zfs_data ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
ata-Hitachi_HUA722020ALA330_JK11A4B8KMA5HW ONLINE 0 0 0
ata-Hitachi_HUA722020ALA330_JK11A4B8KTY00W ONLINE 0 0 0
ata-Hitachi_HUA722020ALA330_JK11A4B8KM9TDW ONLINE 0 0 0
ata-Hitachi_HUA722020ALA330_JK11A4B8KRTM0W ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GK6AWP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GJU3TP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GK4A1P ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GJGTWP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GG125V ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GK7PTP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GKE44P ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GK4STP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GKD01P ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GJVT9P ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GKG1TP ONLINE 0 0 0
ata-HGST_HUS724020ALA640_PN2131P6GJY3HP ONLINE 0 0 0
errors: No known data errors
root@omv-ss4200:/zfs_data# dd if=/dev/zero of=/zfs_data/test4.img bs=100M count=20 oflag=dsync
20+0 records in
20+0 records out
2097152000 bytes (2.1 GB, 2.0 GiB) copied, 22.3055 s, 94.0 MB/s
root@omv-ss4200:/zfs_data# df -h
Filesystem Size Used Avail Use% Mounted on
udev 967M 0 967M 0% /dev
tmpfs 199M 6.0M 193M 3% /run
/dev/sdb1 108G 2.8G 100G 3% /
tmpfs 994M 0 994M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 994M 0 994M 0% /sys/fs/cgroup
tmpfs 994M 0 994M 0% /tmp
zfs_data 25T 5.6G 25T 1% /zfs_data
# dmesg | grep ss4200
[ 10.371447] leds_ss4200: detected 'Intel SS4200-E'
[ 10.371451] leds_ss4200: registering PCI driver
[ 10.373179] ? nas_led_blink_show+0x40/0x40 [leds_ss4200]
[ 10.373250] ? nasgpio_led_set_blink+0x80/0x80 [leds_ss4200]
[ 10.373322] nas_gpio_init+0xf7/0xfe5 [leds_ss4200]
[ 10.373393] ? ss4200_led_dmi_callback+0x1b/0x1b [leds_ss4200]
[ 10.374730] Modules linked in: leds_ss4200(+) pcc_cpufreq(-) rng_core button sunrpc ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 btrfs blake2b_generic raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod sd_mod t10_pi crc_t10dif crct10dif_generic crct10dif_common uas usb_storage hid_logitech_hidpp hid_logitech_dj hid_generic usbhid hid ahci libahci sata_sil24 uhci_hcd ehci_pci psmouse ehci_hcd usbcore libata i2c_i801 i2c_smbus lpc_ich scsi_mod e1000e usb_common ptp pps_core
root@omv-ss4200:/srv/dev-disk-by-label-data1# dd if=/dev/zero of=./test2.img bs=1G count=5 oflag=dsync
5+0 records in
5+0 records out
5368709120 bytes (5.4 GB, 5.0 GiB) copied, 44.5664 s, 120 MB/s
Thanks! So I assume your power LED is also blinking all the time then, right?I redid mine using mdadm on an 8 drive array (4 internal, 4 external). Performance is better than with ZFS Raid:
Code:root@omv-ss4200:/srv/dev-disk-by-label-data1# dd if=/dev/zero of=./test2.img bs=1G count=5 oflag=dsync 5+0 records in 5+0 records out 5368709120 bytes (5.4 GB, 5.0 GiB) copied, 44.5664 s, 120 MB/s
Regarding the LEDs, I have mine sitting in the basement and rarely look at it, so it doesn't bother me.
No, USB 2.0 is way too slow. I have a single 4 drive eSATA array, a G-SPEED eS (without the SATA card), hooked to one of the eSATA ports. The SS4200 eSATA ports support SATA hubs (which is rare for motherboard SATA ports, but I had seen it mentioned in a previous discussion on the SS-4200). I originally also had connected a second 8 drive array to the second port when I was running 16 drives with ZFS, but decided to move that array to a different server.Thanks! So I assume your power LED is also blinking all the time then, right?
How did you attach the 4 external drives? Two USB and two eSATA?
Nice.Howdie folks. I also recently resurrected my dust-collecting Scaleo SS4200-E. Was still rocking the ancient Windows Home Server installation. I wiped everything and installed OpenMediaVault on a 16GB USB stick (one of those teeny tiny ones that barely sticks out). I also obtained a PCI-E x1 to x16 adapter so I could use a proper video card during the installation process, which made everything much easier. Note: One must install and enable the flashmemory plugin to reduce writes to the USB stick.
Years ago I had upgraded this unit to the E2220 CPU and 2GB RAM, and am now rocking 4 x 2TB drives set up in a RAID5 configuration under OMV (I decided against ZFS as the recommended amount of RAM is higher than 2GB).
Wow! I think you've pushed the ss4200-e as far as it can possibly go in terms of drives.I have a single 4 drive eSATA array, a G-SPEED eS (without the SATA card), hooked to one of the eSATA ports. The SS4200 eSATA ports support SATA hubs (which is rare for motherboard SATA ports, but I had seen it mentioned in a previous discussion on the SS-4200). I originally also had connected a second 8 drive array to the second port when I was running 16 drives with ZFS, but decided to move that array to a different server.
I haven't measured the throughput yet (there's hardly any data on my array yetNice.What version of omv did you install and what type of throughput do you get?
Nice.I haven't measured the throughput yet (there's hardly any data on my array yet), but the OMV version I installed is the latest stable version 5.6.13. I have no prior experience with OMV, but have been using Ubuntu Server on another box of mine for many years. And as both OMV and Ubuntu are based on Debian, it all feels very familiar. Additionally, really like the web interface for those who don't want to poke around Linux.
Wow! I think you've pushed the ss4200-e as far as it can possibly go in terms of drives.Great to have a confirmation of the port multiplier working and being reliable. I actually have an 8 bay sandigital esata enclosure I bought with the intention of using with the ss4200-e, but it has found usefulness elsewhere for now.
Yep, I don't know how I missed that earlier because you had a whopping 32TB running from an ss4200-e, which I think is a world record.Actually if you read back a few messages, you'll see I actually had 16 drives connected at one point, but I too found another use for my 8 drive array (not a Sandigital, although I do have one of those as well). I think the max is 20 (16 external, 4 internal) without resorting to USB.
yhpm!So it was fun reactivating my upgraded & fully loaded SS4200-E (see above) and playing around with OpenMediaVault, but I want to find a new home for it (well, really my wife wants me to). If anyone is interested, please PM me. Thanks.
Welcome To SNBForums
