Treadler
13+ hours both router & wifi uptime here now.With my AX88U, I have no Scripts, all options are almost default and as I said before, nothing to report on the LAN/WAN/WIFI/VPN.
I flashed the 386.7 version from the 386_5.2 then did a WPS reset + formatting of the JFFS partition + reboot (I insist on this point to avoid any problem) I then manually reconfigured all my settings (without importing a backup) and did a last reboot to apply.
Here is a screen from my work laptop that has been connected in 5 Ghz (auto channel, everything by default) since 07H00 today without any problem.
I turn the computer on early in the morning and turn it off at night when work is done. I have been doing this for over 11 days now and no interruptions.
I also have android smartphones that connect and stay connected for more than 3 hours (when I watch youtube) without any problem.
Solid as a rock.
Too early to get excited, as 55+ hours before wifi failure has been seen prior to full reset…..
After reset procedure, I introduced the amtm scripts I run, one at a time.
Reboot after each install, & check operation.
Installation of the final one (YazFi) caused the 5ghz LED to turn off, & yes, that radio was dead. Reboot, it came back, then had a couple of wifi (2.4 & 5) disconnects in quick succession as previously mentioned.
Currently running with YazFi uninstalled, if I can get more than 55 hours uptime, I guess I’ve found/fixed my issue?
