GHammer
Didn't literally mean you in the first part but that wasn't clear especially because I did in the second part. "If someone" is more accurate.
But do you use ULA?![]()
I'm more of a Uma kinda guy.
Are you sure you're in the right place? This is the SMALL NET BUILDER forums. I'm afraid you may be conflating the home aspect of networking and your commercial activities, friend:Hey, sound dude! Don't forget your toy router and YouTube network is much different than my networks. You can play with IPv6, QUIC, DoH and scripts written by lonely coders all day long. I can't and in some parts not allowed to. Otherwise I may have to join your networking club and I don't want to.
Touched a nerve, I see...Yes. My networks are under 200 clients each. You virtually have no "network". Perhaps the worst reliability Asus home router with software bugs on top, slow DSL Internet connection and a bunch of personal devices. You have nothing much to care about. Your IPv6 enabled and not needed may lead to traffic leaks, your Unbound server installed and not needed may reveal your external IP address, some scripts you advise other people to install are just destroying your connection or regular intervals, etc. You stopped here at this thread to share what exactly knowledge and experience?
Always nice to see how IPv6 brings out the best in us all.
I've read through this entire thread and decided to chime in on this as an outsider with an observed benefit to using IPv6. I say 'outsider' because I no longer use an Asus routing device, instead I use pfSense for my router/firewall. I ran with IPv6 enabled for several years and during that time, there was a period of a few months where having IPv4 + IPv6 added value to my home network experience. I have Comcast for my ISP and during the spring/summer of 2021 they were apparently having issues on their system which would manifest by dropping packets on my IPv4 connection, however, my IPv6 connection would remain perfectly functional. These asymmetric outages would seem to coincide with high wind events in the neighborhood. Ref Xfinity forum thread: https://forums.xfinity.com/conversa...-on-windy-afternoons/6087431943a1b761d4e812dbSeven pages and no one touched a single benefit of IPv6 enabled when public IPv4 is available...
After months of complaining to Comcast, the problem eventually went away. Not sure if it was from my complaints or just a result of normal system maintenance...
So, I can say from experience that having both IPv4 and IPv6 enabled was beneficial, although somewhat limited. I say limited because I work from home and since my work VPN is strictly IPv4, I was not able to work through the ISP IPv4 outages. But, I could still surf the web...
Since then, I have disabled my IPv6 connection. Overall, I found it frustrating to look over my state tables or firewall logs and not be able to recognize any of the IPv6 traffic that was flowing through my network to the outside world. With IPv4, I can easily identify device classes based on their VLAN subnet IP, or even recognize outside IPs such as Microsoft (20.0.0.0/11). I thought I would eventually learn to read IPv6, but it still looks completely foreign to me. So while I did indeed see a benefit to running both, I eventually succumbed to just using IPv4 for simplicity sake...
Easy enough - leading by example... put up or shut up on ipv6
Dropbox - File Deleted - Simplify your life
www.dropbox.com
but it will become more restricted over time
Going off the grid?I plan to drop all IP related issues in next 10 years anyway.
Since sharing is caring:Just wanted to share...
Bufferbloat and Internet Speed Test - Waveform
View the full results, and test your own bufferbloatwww.waveform.com
It's not the fastest thing in the world, but at least we have bufferbloat and AQM for WiFi under control - as well as IPv6...
Not bad for a 15 year old chip in 2.4GHz on a noisy 2.4GHz network![]()
When using dual stack, IPv4 & 6:
I notice when doing a port scan, an IPv4 scan shows all ports as being in ‘stealth mode’.
However, when doing an IPv6 port scan, most (not all) ports show connection ‘refused’ rather than ‘stealth’.
Is this an anomaly?
Welcome To SNBForums
