commodoro
Thanks for the clarification, I learned a new thingStarlink does things a bit differently:
Can You Get A Static IP From Starlink? | DISHYtech
Starlink doesn't offer static IP addresses. You can get a public IP on the Priority plan, but a better workaround might be using a VPN service.www.starlinkhardware.com
Starlink Router Configuration Guide | DISHYtech
Learn how to easily set up and configure your Starlink WiFi router using the Starlink app.www.starlinkhardware.com
See Hacks section: https://hackaday.com/2021/05/24/starlink-a-review-and-some-hacks/
Can I change the IP address of the Starlink router?
by u/mVat in Starlink_Support
External IP's assigned to Starlink Users
by u/murf-in-wyoming in Starlink
How To Use Your Own Wi-Fi Router With Starlink
Want to use your own Wi-Fi router or mesh system with Starlink? Chances are it's compatible, if you buy a simple adapter. Here's how to find the best router for Starlink to take your coverage and speeds to the next level.www.pcmag.com
Starlink Update: February 2021
I wanted to share some additional insights I’ve garnered on Starlink service. Some of it from a YouTube video / its description (Thanks to Phil Armishaw for posting it in a comment on my Dece…turtleherding.com
Do I get a public IP address with Starlink? Not at this time. Starlink uses Carrier Grade Network Address Translation ( CGNAT ). This is the same technology used by cellular carriers and commonly uses an IP in the 100.64.0.0/10 range.
