Skynet Is default firewall good enough?
Hello! Can anybody help me please? I faced this issue after installing Skynet and cant find any working solution or understand what caused it. Do you have any ideas or solutions how to fix that?
[1-5]: 2
Input Custom Filter List URL:
[URL]: https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
[$] /jffs/scripts/firewall banmalware https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.
killall: syslog-ng: no process killed
[i] Custom Filter Detected: https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
[i] Downloading filter.list         | [0s]
[i] Refreshing Whitelists           | [8s]
[i] Consolidating Blacklist         | [0s]
[*] List Content Error Detected - Stopping Banmalware
[#] 1 IPs (+0) -- 0 Ranges Banned (+0) || 0 Inbound -- 0 Outbound Connections Blocked! [banmalware] ]
[i] Press Enter To Continue...
I encountered this when re-installing Skynet 7.5.8 after a long time of using AiProtection. I think there maybe either website-file-content issue with Github, or Skynet itself. Because I got this issue when either:
1/ Importing ViktorJp list
2/ Creating my own "filter.list" on Github because I had wanted to customize my own firewall rules. This issue had happened again, until I recognised that I had to use the Raw file format. However, when modifying the file, sometimes Skynet warned me of "invalid file date format" and refused to use it. I tried removing and reinstalling Skynet with no luck, until it resolved automatically and "magically" after I imported Somewhere Over The Raibow list below :rolleyes:
https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
Although Skynet did show the "List content error", it still imported the file. Futhermore, a mysterical thing was that when modifying my file on Github and importing it in Skynet again the day after, there was no error at all.
P/s: I have an AX-88U with Asuswrt-Merlin 3004.388.6_2, and using latest of Diversion, Skynet, ntpMerlin, CakeQoS, MerlinAU and BackupMON.
I have the same router and very similar apps (all updated), but problem is persistent. And i tried the second link too - result the same:
[1-5]: 2
[URL]: https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
[$] /jffs/scripts/firewall banmalware https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/ma
[i] Custom Filter Detected: https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filtet
[i] Refreshing Whitelists           | [7s]
It seems the problem is in Skynet or conflicting apps. But where to dig and how to fix it? Do anybody have an idea?
[1-5]: 2
Okay, from the SSH command line connected to the router, run this command nslookup raw.githubusercontent.com.
Also, from the SSH command line connected to the router, run this command ping raw.githubusercontent.com .
Here is an example of what you might expect to see if both DNS and connection to the IP address's for the domain are working correctly:
admin@RT-AX88U_Pro-27C8:/tmp/home/root# nslookup raw.githubusercontent.com
Server:    192.168.1.1
Address 1: 192.168.1.1 brother.lan
Address 1: 185.199.111.133 cdn-185-199-111-133.github.com
Address 2: 185.199.108.133 cdn-185-199-108-133.github.com
Address 3: 185.199.109.133 cdn-185-199-109-133.github.com
Address 4: 185.199.110.133 cdn-185-199-110-133.github.com
Address 5: 2606:50c0:8001::154
Address 6: 2606:50c0:8000::154
Address 7: 2606:50c0:8003::154
Address 8: 2606:50c0:8002::154
admin@RT-AX88U_Pro-27C8:/tmp/home/root# ping raw.githubusercontent.com
PING raw.githubusercontent.com (185.199.108.133): 56 data bytes
64 bytes from 185.199.108.133: seq=0 ttl=58 time=13.131 ms
64 bytes from 185.199.108.133: seq=1 ttl=58 time=10.085 ms
64 bytes from 185.199.108.133: seq=2 ttl=58 time=14.524 ms
64 bytes from 185.199.108.133: seq=3 ttl=58 time=9.956 ms
64 bytes from 185.199.108.133: seq=4 ttl=58 time=9.386 ms
64 bytes from 185.199.108.133: seq=5 ttl=58 time=9.319 ms
64 bytes from 185.199.108.133: seq=6 ttl=58 time=12.775 ms
64 bytes from 185.199.108.133: seq=7 ttl=58 time=16.718 ms
64 bytes from 185.199.108.133: seq=8 ttl=58 time=17.677 ms
64 bytes from 185.199.108.133: seq=9 ttl=58 time=11.613 ms
^C
--- raw.githubusercontent.com ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 9.319/12.518/17.677 ms
If anyone's interested, I've been using my own custom filter list for Skynet... plug this URL into Skynet and profit:
And yes, it contains all 3 Firehol lists as well. ;)
Maybe this is asked before.
Where (in which option of Skynet 3 or 5) to put it?
Should I replace the Blacklist?
It seems the list https://github.com/firehol/blocklist-ipsets/ really corrupted my Skynet. But I found the second reason of my issue too - I used DNS-over-TLS and one of choosen DNS servers worker improper. So I totally uninstalled Skynet, reseted WAN DNS settings and setted them again in a proper way. Now two custom lists as the original one are working and updating correctly. Thank you for support! 🤝
You can select option 3 - Malware blacklist, then select option 3 - Change filter list, and paste the URL of your chosen one. Once doing that, Adamm default filter list will be replaced with yours.
Is a big difference between the lists?
Or are the almost the same?
Do I need to update the custom list?
Since being a normal user, not a cybersecurity expert, I think differences among the lists are the amount of sub-lists, and number of blocking IPs. Because each list owner tends to customize their list to their firewall rules, they would add or remove some sub-lists inside.
In terms of updating the custom list, I think you do not need to because most of the sub-lists are updated automatically. Furthermore, as using other users' list, you cannot modify it, unless you create your own one on Github.
My piece of advice whitelist these domains:
github.com
